    Can Scaling stokes and effects be on by default? Can we make it easier to switch all child sublayers by editing the setting at the parent level?
    25 Posts 6 Posters 33.4k Views 6 Watching
      @Boldline I have no idea if it was the novices or avoiding unwanted stroke differences you need to fix afterwards, or both, but I guess you enabled the 'Scale Strokes & Effects' option in AI's Preferences > General and forgot about it. That's why you didn't have to worry about if afterwards. 🙂
      IMO it's best to have a setting for this in Preferences AND an easily accessible toggle in the Transform or Stroke panel.
        @b77 said in Can Scaling stokes and effects be on by default? Can we make it easier to switch all child sublayers by editing the setting at the parent level?:
        It's very possible 🙂
          Subpath @b77
          @Subpath I'm all for an easily accessible toggle for this, but not for being the default mode of operation.
          Is AI, CDR, AD and Magix Xara like this by default?
          (Rhetorical question, btw). 🙂
          Do not know it for AI because I do not use Illustrator
          (You may remember, I don't like the user interface and the handling 🙂
          To answer your question:
          I would say CDR and AD definitely not.
          Magix Xara also not, in a new installation.
          But as I wrote, once set it stays active even if you restart the program, until you turn it off again.
          The Toogle is as I wrote in the Contex Bar and very easy to reach.
          Here a Pic:
          I have no particular need for it, so I can live with a toggle
          But unfortunately I have to honestly say that the VectorStyler method of scaling strokes is,
          in my eyes, the most unsual I came across
          ( maybe because of the roles and styles ? )
          ( I dont like it and haven't found, until this time, any beauty in it yet, that's why I don't use it )
          in every other vector graphics program that i know, it is so much more seamless and easier.
            Boldline @Subpath
            @Subpath said in Can Scaling stokes and effects be on by default? Can we make it easier to switch all child sublayers by editing the setting at the parent level?:
            I'd be interested to hear what you feel would improve it and make it more of a seamless process - also what do you do instead of scaling in VS?
              @Boldline There is also a "Transformed Stroke" option in Document Setup. This will affect newly created objects.
                Subpath @Boldline
                As i only play with graphics and try out the ideas that go around in my head.
                ( Dont work no longer as a professional )
                For this i use the programs that have the tools that can help me with the realization.
                Short note and praise for VS:
                Since VS has so many useful and interesting tools by the way, I try most ideas in VS
                since I bought a copy. (I think that says a lot)
                I don't really have a need for scaled strokes if I need it,
                I just set a different stroke width
                If I really need it I would try to copy my design into AD, CDR or Magic Graphics Designer
                and get it done there. (or maybe solve it via the outline effects ?).
                ...I'd be interested to hear what you feel would improve it and make it more of a seamless process...
                As i dont really know the Concept behind it, why it should or must work this way
                (never saw something like this before)
                i can not say how to streamline it
                ( toggle could be a first start ? )
                  Boldline @Subpath
                  Maybe we are thinking of two different things? I'm talking about designing something at one size and then needing to group it and scale it up - the entire design element with fills and strokes included and wanting them to all stay relative in size to one another in the process.
                    Subpath @Boldline
                    @Boldline said in Can Scaling stokes and effects be on by default? Can we make it easier to switch all child sublayers by editing the setting at the parent level?:
                    well, dont think that we talk about different things. That you like to scale your entire design elements
                    in relative in size to one another, is very clear to me.
                    But i cant help you out in this case.
                    Edited:
                    (well you mentioned yet effect scaling and i wrote only about stroke scaling )
                    i just wrote that i am not in need of this kind of scaling in VS and i dont like
                    to used it in VS. So if i need some different stroke width
                    i just set it.
                    • DazmondoD Offline
                      Dazmondo @Boldline
                      A sticky button would be really handy for this as 90% of the time I need strokes to scale
                        VectorStyler @Dazmondo
                        @Dazmondo When creating new documents, enable the "Transformed Stroke" option in the Document Setup -> General view.
                        • DazmondoD Offline
                          Dazmondo @VectorStyler
                          Doesn't work for me - the strokes only scale when grouped ????? or if scale image filters is ticked
                            b77 @Dazmondo
                            @VectorStyler It looks like it doesn't work for parametric shapes (smart shapes). Easily fixable, I guess.
                            @Dazmondo Convert them to curves and this works as expected.
                              VectorStyler @b77
                              @Dazmondo Yes, a few parametric shapes are not "scaled" (rectangle, ellipse).
                              An other way to go around this is to disable the Direct Shape Transformation option in Preferences -> Editing Options 2 (bottom-right corner).
                              • DazmondoD Offline
                                Done and working ----👍
