    2. Features and Ideas
    3. Implemented Features
    • Text placeholder text improvement
      7004
      @Boldline I open a bug, to use the last selected text size when creating text shapes. About the additional tools (scaling) while in text mode. In AD the resize box is shown around the text. I think this could be added later if it does not complicate things too much. In VS the same is achieved by selecting the pointer tool and resizing the text just like any other object (but this deactivates the text tool). One thing that VS has: when editing a shape text (a.k.a point text), when holding Command the baseline can be adjusted as a regular path. And selecting the node tool, will edit the baseline as a regular path.
      Pinch zoom around cursor
      • statestreet
      7807
      This is so much better! It's one of those little things that makes a big difference.
    • Zoom and Simplify Path
      9855
      @vectoradmin Thanks. Works as expected now (win10).
    • Can the creation of New Layer Not open Dialog Box Each time?
      5988
      @vectoradmin This is great! I love the option to hold the option key if you want the layers dialog box to open for a new layer and also the double click of an existing layer to access it that way post-creation.
      Tool option: erase up to intersection
      • postdes
      30
      30
      63160
      Yep, looks good now. Thank you!
    • Pen tool snap to end point
      6680
      @vectoradmin Nice, it's subtle and effective. Great improvement thanks!
      option for layers panel: checkerboard background
      • postdes
      6577
      @vectoradmin Build 207 adds checkerboard background in Layers and Appearance panel preview boxes.
    • Offset Path slider option
      6882
      Thank you - looks good. just tried it out
    • Scaling jpegs cursor icon
      4629
      @Boldline We need some kind of indicator of what will happen at a specific location with the box selection. This can be move, scale, rotate, skew. These are indicated with cursors.
      Pen tool improvements
      • postdes
      15471
      @vectoradmin There are additional improvements for the pen / node tool in the new build 201
    • Bitmaps
      10129
      @Boldline I tested this and could not replicate it.
    • Brush default should be plain?
      10079
      @fde101 Using solid stroke as a default brush should work in the new build 201
    • New From Clipboard
      • badcat
      6736
      @badcat Yes, that can be added.
    • Guideline coordinates during creation
      • badcat
      6519
      In build 200, guideline coordinates are shown by default when creating.
    • Allow (better?) keyboard control in Preferences?
      • badcat
      5114
      @vectoradmin In the new build (200), up and down arrows should work in browsing the preferences.
    • Handles affecting both sides of node equally in a not good way
      7063
      OK I will play around with those setting more - thank you @Jae and @vectoradmin
    • Stroke sizes pre-set
      4211
      @Boldline This could be done for the default set.
    • Real time opacity preview in layers panel
      4054
      @Boldline Following steps: open both the Layers and the Transparency panels. select the whole layer in the Layers panel, by clicking on the round circle at the end of the row with the layer name. this creates a single object selection, where the object is the layer (can only be done in this way. now with the layer selected, adjust the Opacity slider in the Transparency panel. the result can also be verified, that it applied to the layer (and not those objects) in the Layer Options (or just double click the layer name in the panel).
      Some thoughts on tool organisation UI
      interface tools • • postdes
      22
      22
      57673
      Yes, this seems to be working again. Thank you!
      Visual feedback when using modifiers in shape sketch tool
      • postdes
      18314
      Cursor handling improved in build 198
