  • Saving indicator color
    C
    @Boldline said in Saving indicator color: I'm not saying it needs to stay purple, but I do like that it's a subtle change that does not distract from my work, yet it is noticeable as it changes. Maybe if it went to orange then red? Purple is a very difficult color: In the dark UI you notice it too late and when you notice it, it disturbs your design colours no matter what color. Orange and red are too similar. The classic sigal colors are green, yellow, red. Maybe a slightly muted yellow, like R255/G255/B150 or just red?
  • Option to save imported file directly to same folder and same file format
    @fde101 said in Option to save imported file directly to same folder and same file format: What it is actually doing is importing the PSD but remembering where it came from and what it is, and when you "save" the document, it replaces the original PSD with a newly exported copy instead Yes, but it will lead to loss of information. I will find a solution for this.
  • Please add a 'search next' in the Customize windows
    Thanks all. I think these arrow-buttons are more obvious and intuitive and I agree that it's best to keep UI consistent. Nice to see this added, because this is one of those hidden features that are easy to forget, let alone for newcomers.
  • Please search keyboard shortcuts on name instead of shortcut
    @encart said in Please search keyboard shortcuts on name instead of shortcut: Perhaps when the shortcut configuration window is opened, icons should be visible next to the labels from the beginning to indicate that sorting is possible I added this to the backlog
    @fde101 said in Please have 'Enter' not close a window (at least not the Customize windows): If your other applications are behaving differently, it is your other applications that are wrong. Sure
  • Please make keyboard shortcut Ctrl+Enter available!
    @VectorStyler said in Please make keyboard shortcut Ctrl+Enter available!: I will try to fix this. Is this on Windows or Mac? Thanks. I'm on Windows here
  • Brush "live" randomization thread - continued
    @Harry The original randomization request was about creating "grunge" shapes. This is still an open task in the feature backlog. But we can do other customization (not yet random) now with number variables. If the brush content uses some number variable, that can be changed in the Values panel or in the Overrides panel.
  • Pasting text from clipboard does not replace highlighted text on path
    @Boldline Bot sure why this happens. About how long was VS running before this occurred?
  • Future Arc Tool modifier options
    @Harry love it Coming from CorelDraw, I always forget about the shapebuilder, grrrrr
  • Displaying dimension box with the selection cursor
    @creative I added this to the backlog for the 1.3 features.
  • Picking colours outside VectorStyler
    C
    Other apps on macOS, as the free version of ColorSlurp are working too for picking the color and paste the color code using command+v.
  • CSS Properties Panel like in Fireworks
    With all of the capabilities the VS has, it would be great to have direct project export to html / css. VS could be great alternative to Figma.
  • Aspect ratio field in the Transform Panel
    C
    @VectorStyler Percentage would not be as useful as 1:2, or 1:1.61803398875 type field
  • Aspect ratio checkbox
    C
    @VectorStyler Yes, if the transform tool is used for scaling or precise scaling via the transform planel, e.g. if I set an aspect ratio of 1:1.618, it remains locked so with further scaling. A aspect ratio field in the transform panel would als be convenient.
  • New document setup (mouse wheel)
    @Pat said in New document setup (mouse wheel): impossible to get a number without a decimal I will try to improve this.
  • iPad app?
    @VectorStyler woooow, great !
  • Free rotation of the artboard via the trackpad
    @creative enable Settings -> Document Editor -> Rotate View with Trackpad
  • Object properties interchangeable between open documents
    @Harry said in Object properties interchangeable between open documents: Is it possible to use Picker tool to pick object properties (E.g. style, color, effects etc.) between open documents Not possible with the picker tools. But it is possible to copy / paste appearance (or other properties) using the Edit -> Attributes commands.
  • Illustrator UI as inspiration?
    @creative The properties panel will be improved.
