  • Small Improvement to Panel Snapping
    @debraspicher I added this to the backlog.
  • Menu focus should follow cursor
    @debraspicher I will try to modify this.
  • Polar Grid Tool
    For VS, I was thinking more of a "concentric grid" parametric shape option to get a "polar grid/radar" type of graph
  • Affinity Designer import
    7 Votes
    No, it's probably not simple, but perhaps this project could be of some help. I'm sure they've reverse-engineered it. I hope you can find a good lead. It's precisely a format shared by all three applications, so I hope the vectors are reasonably separate and identifiable. My big curiosity is whether it's a spaghetti format—or if it's well-designed.
  • Regarding the halftone repeater types
    76
    205k Views
    @VectorStyler Sorry, I've been a bit busy lately. I didn't explain clearly. I meant multiple blended shapes, not a single blended shape. I couldn't find the files I make on before. I'll redo them when I have some time and send them to you.
  • Help with Path Brush Tool
    @VectorStyler: Thanks a lot!
  • ruler editing
    @ZATOPEK This is in the backlog for 1.3 (later)
  • Thoughts on the Distortion Tools
    @VectorStyler said in Thoughts on the Distortion Tools: @Subpath I added this to the features backlog, and I will try to find a solution for 1.3 some distortion Tools into one Tool This last point is not clear Let's say you have 4 distortion tools that are most similar, e.g. in terms of settings. That these could perhaps be combined into one tool and the options of the 4 tools could then be accessed via a dropdown menu in this combined tool. This could reduce the number of distortion tools somewhat but keep the features of it. Just an Idea dont know if this makes sense.
  • Pucker tool like functionality.
    @Subpath @VectorStyler Thank you very much for the help. Needed this function for a project work. I can use both the circular and liquify brush settings shared here. I agree illustrator tools are very fluid over VS brushes, may to find the right settings and speed as you pointed out.
  • Pen Tool
    @monsterfox I add this to the backlog for the future.
  • calculate the centerline
    @monsterfox I will add this to the features backlog.
  • Select two open nodes to join automatically
    @Li-Xiao as I wrote before VectorStyler is the "Swiss Army knife of vector graphics"
  • Split Text changes alignment of text
    @VectorStyler Thank you.
  • Extending options in the Transform tool
    @Boldline Most of these additions will be for 1.3.
  • Separation of the stroke and the arrow
    @William-Kansepa your welcome Here is an example from me, I once had the idea that it could be useful for a circuit board like graphic design so i made me this custom Arrow Head [image: 1721205538458-circuit-boards.png]
    @VectorStyler said in Can the Bucket Fill Tool be improved by allowing it to create shapes based on negative space between paths?: I will add the fill/stroke in the next build. This will be a very helpful added function! thank you
  • Transforming tools need to be upgraded.
    @VectorStyler VS currently has several transformation tools that operate outside the selection box, and what is needed now is a tool that can operate within the selection box. Freehand and Ai both have tools that can be operated within it, and you can experience it.
    @Boldline I will add this to the features backlog for now. I will try to find a solution for these issues.
    @Boldline Should also be configurable in the Settings -> Modifiers section.
