      Black in CMYK profile is not black
      • A Former User
      10418
      @Torakikiii said in Black in CMYK profile is not black: make sure that display and output of rich blacks are optionals Will do so.
    • I
      All's working Fine.
      • Inspiredmac
      2456
      Export & UI Question
      • KT
      3712
      @b77 It does also happen with Save & Open, thanks for reminding me. I've been exporting a lot past few days so I guess that was fresh in my mind when I wrote this. I double checked, and it is set to Dark not Extra Dark. @VectorStyler thank you very much! I appreciate it.
    • I
      Non-Responsive App
      • Inspiredmac
      4458
      @Inspiredmac One other thing: open Activity Monitor and check the CPU usage of VectorStyler while it is launching.
      Transfering serial
      • Petar_MK
      3356
      Thank you very much. You are great.
    • Correct setting for display and print in CMYK?
      5480
      @VectorStyler Wow! Thanks! A very detailed, comprehensive and useful feedback! If you consider an addition to the online guide you have already outlined the content copy with this response to me:) Consider also how-do-I-cases like "I want the artwork to appear on the web" and "How to set up artwork for print: how do I manage destination profile and screen appearance".
    • What does this cursor symbol represent?
      8087
      @VectorStyler Thanks - I think the issue for me is that the collider tool is set to the forefront in that tool grouping by default and even if it's not being used, if it's icon is visible in the vertical tool bar, it affects the way the transform tool can be used. I was getting the collider symbol to appear by my cursor even when all I was doing was trying to shift-click several overlapping vectors - this caused them to not select properly. I was not trying to use the collider tool, at all in this case and it still was in part activated. This is a similar issue with the magic wand tool - if it's the visible top toolbar icon in it's set on the vertical toolbar, other selections cannot be made until it is switched away from entirely.
    • Polygonal Lasso
      3225
      @Ingolf There seems to be a problem here, opened a bug on this one.
    • Was the shortcut to click on a file name tab to see it file location removed?
      7879
      @Jayanta-Das I check what happens on Windows. Normally, it should open the file Explorer and highlight the file.
    • Why does the path go straight and then back to a curve when clicking on last node to make cusp?
      3086
      @Boldline I will try to replicate this, added it to the backlog.
    • [Bolean operations] Divide, Trim and Merge expands stroke automatically.
      5212
      @b77 I will add the configuration options.
    • Should live text be rotating as it is scaled?
      2579
      @Boldline Group the whole selection, and then scale it.
    • Copy color, size and tracking of one text example to another
      7255
      @Boldline Regarding the pasting of styled text: A separate 'Paste and Match Style' command in the Edit menu might be better than another entry in Preferences.
      Two Brush drop down list?
      2522
      @Jayanta-Das Error! Will be fixed.
    • Pattern Brush Questions
      6187
      @VectorStyler Thank you I know already that Symbol would also work to create a Pattern Brush. But forgot to mention it in my Post above.
      How to save as template
      2556
      @Jayanta-Das There is no special command to save it as a template. Just save it as a regular vstyler file and then use New from Template to select it.
    • Speed of fonts list scrolling
      2960
      @encart No settings for this. I add this to the bugs, will try to find a solution.
    • Selecting Contiguous Nodes in a Sub-path
      • Victor Vector
      15219
      @VectorStyler Thank you for considering this idea. Perhaps a modifier key and a right-click? Currently right-click brings up a node menu when nodes are selected. Maybe modifier key + right-click brings up a little menu showing the all the selected nodes and maybe the user can click to check them off or on? Nodes would be sorted from last to first, top to bottom? I am sure you or others may have a more elegant solution, just trying to help ...
    • Could Split Text retain settings?
      2790
      Minor thing about inserting a node
      3432
      @VectorStyler I think i got it, understand your thoughts. Thanks for explanation.
