    Skew while in transform tool
    7 Posts 4 Posters 6.6k Views 3 Watching
    • J Do not disturb
      Jayanta Das
      Is there any option in preference to enable skew in transform tool. Like this in this recording
      Mac Mini M4 Pro | 24Gb
      WIndows 11 | Intel i5 11Gen
      Wacom Intuos Pro
      • b77B Offline
        b77
        @Jayanta-Das Is 'Rotate with Knob' selected in Prefs > Adjustments > Selection Box?
        In the default configuration (Rotate from Corners) skewing an object can be done with the Transform tool (shortcut: V) directly if you place the cursor on the sides, near the handles.
        J 1 Reply Last reply Reply Quote 1
        • J Do not disturb
          Jayanta Das @b77
          @b77 Thanks. Rotate with knob is enabled.
          Wacom Intuos Pro
          • b77B Offline
            b77 @Jayanta Das
            @Jayanta-Das The 'Rotate with Knob' option was introduced later at users' request, but I think skewing should be made to work with it as well.
            J BoldlineB 2 Replies Last reply Reply Quote 0
            • J Do not disturb
              Jayanta Das @b77
              @b77 Yes. I like rotating object with knob and also would like to skew at the same time with transform tool.
              Wacom Intuos Pro
                Boldline @b77
                @b77 said in Skew while in transform tool:
                This all makes sense now what @Jayanta-Das was requesting. I remember when the knob was requested.
                I too, use the "default rotate from corners" myself
                  VectorStyler @Jayanta Das
                  @Jayanta-Das said in Skew while in transform tool:
                  In default mode, when hovering slightly outside of the nodes at the center of the edges, the cursor turns into "skew" mode
