    • Should align panel be added to the contextual menu when multiple items are selected?
      13524
      @encart ok I get it now - that works. thank you for showing me that
    • Potential Brush issue
      3458
      @Boldline Yes, the brush tool will always switch form the plain (solid stroke) to a brush. This is by design for now. To paint with a plain stroke (including tapering), use the Pencil tool. II open a new bug on this one, to have the brush tool paint with solid stroke also.
    • Rounding the corners
      corners rounding • • encart
      14191
      @encart Box selection of corners is an open issue (not always working right). I also managed to replicate the issue on Windows (Control+Click is not working). I will open a new bug around these corner issues.
    • Select>Outline> Variable Width Brushes not working?
      4394
      @Boldline For example, you have a drawing with lots of these brush strokes (tapered, or just variable width from pressure sensitive tablet). You want to find them so that you can expand and convert to curves. That is when you use this select action.
    • 4 new actions in the Object menu, to expand clipping groups or to clip objects into a shape (without the need of clipping groups)
      4441
      @vectoradmin Wow my mind is blown!.... I need to take some time with this! Thank you for explaining. This is awesome
    • Text rotate center by default?
      7727
      Thank you for fixing this! I will test it out more but I'm liking that it's right in the center by default now
      License server down?
      • statestreet
      3942
      Thanks for the fast reply! I just activated now.
    • live Warp settings do not carry over to another VS document
      4299
      I tried to replicate it again as well. I think I had copied it when it was still selected using the warp tool. When I tried again using the transform tool, it carried over the warp successfully to the new document
    • Adjusting length of rope stablizer
      3751
      @vectoradmin ok thanks - I had accidently shrunk my box some and that was obscured - my fault.
    • Sampling Colors from imported images/ artboard/background
      4452
      @Boldline It's in the name of the tool — Copy Style. Simple click with it copies the fill(s), stroke(s) AND the image effects of another object. Shift-click picks only the fills and strokes from vector objects and color from bitmaps.
    • How to merge blended objects into one shape/ delete original shape option?
      6521
      Ok.. Do what works best. I'm not a programmer. I guess what I was seeing was that the initial pieces used to make the blend were left behind after the blend was made. But I'm not saying I'm right or what I'm suggesting is best
    • How do I create a Compound path?
      5086
      @vectoradmin Thank you for explaining! This makes more sense. I had seen the combine option in the boolean operations panel but my Illustrator brain was not computing that - I get it now
    • Should "Locked" be renamed "Lock" "Hidden" be "Hide"?
      3445
      @Boldline Will do so.
    • Path Simplifier Tool same as Smooth Tool in Illustrator?
      16051
      @vectoradmin When you add it, it could probably go in the same place the path simplifer is now - or it could be a built in part of the path simplifier and make it a toggle or option as to how it gets used. Just my thoughts
    • Rotate View Tool Return to 100% upright
      4071
      @vectoradmin I also like the tool for rotating and getting back to the initial angle located at the bottom left of the app. Just really 'noticed" it That is helpful as well. Easy access and location
    • Thanks for small hidden tweaks
      2844
    • Pen Tool Guide Toggle
      4433
      @b77 thanks - sometimes it's hard to know where to look in the preferences. "changing options" wasn't clear enough to me to know to go there. Not that I have a better name idea lol. thanks again
    • how to clean up space at top of VS screen?
      7469
      @vectoradmin Thanks! the Shift-Option-Command ultimately solved it.
    • Paste Below place objects in between initial selection
      3307
      @encart Can be replicated! Added to the backlog as a bug.
    • Inking Process Help
      30
      30
      57520
      Great! This would offer a solution the times users want to make use of the pressure option and still expand and divide those pressure based strokes. Thank you!
