    3. VectorStyler 1.0 Bugs
      Shortcut set in VectorStyler->Keyboard Shortcuts not displaying on menu
      • jpsimmons
      2362
    • Vector object display not keeping up with nodes
      9048
      I see this from time to time on macOS although when dragging nodes. Only happened on some objects and not always. Got the impression that what I experienced happens after VS has been running for some time and something has been triggered along the way before this happens. I have a handful of observations I suspect are bugs but need more evidence and observations before I can establish a (probable) pattern and report them.
    • Harmonize stroke, color and appearance panel
      5178
      @Ingolf I could not replicate 2 and 3 either. Could be some issue in the Appearance panel.
    • [Corner Editor] Missing handles
      12125
      @vectoradmin said in [Corner Editor] Missing handles: When the PC is put to sleep, is VS running? Yes, it happens. I'll change this habit.
    • activate lasso tool by holding Option - stops working consistently after 10 min
      6753
      @vectoradmin Interesting thing - the lack of function with this tool is not across all files open at one time in VS. I had three files opened at different times and one of them does not allow the tool to work properly while the other two do. Here is a video of that You can probably also see in the video - that when files are open for a while, weird things happen when you got back to a file. I don't know if timing is always short - because these files have been open for a while now - more than 10 min
      Copy and Paste don't work as expected
      • buckycore
      11009
      @buckycore There have been fixes to the pasteboard in the new build (1.0.048). Let me know if this issue can still be replicated.
    • V
      Layers Panel closing indiscriminately, intermittently.
      • Vector-Rock
      9729
      @Vector-Rock Can this be still replicated?
    • Background flickers with "store history" enabled
      5360
      @Boldline I add this to the backlog. It should work on El Capitan also.
    • Background image slight movement/transform tool moves object on selection
      4873
      Pen tool still not working properly in Build 201
      • postdes
      10122
      @postdes Yes, this one I could not replicate it yet. Will keep looking.
