Title:
Custom shortcuts assigned via Customize Shortcuts do not appear on menus
Description:
I’ve assigned a custom shortcut (e.g., Command-4 for Show All) using the VectorStyler → Customize Shortcuts dialog.
The shortcut works as expected — I can use Command-4 to trigger Show All.
However, the Command-4 shortcut does not display next to the Show All command in the menus.
This makes it harder to verify or remember assigned shortcuts during normal use.
Expected behavior:
After assigning a shortcut via Customize Shortcuts, the corresponding menu entry should display that shortcut next to the command, just like default shortcuts do.
Version:
VectorStyler 1.073 (Mac)
Why it matters:
This would align VectorStyler with standard macOS app behavior (e.g., Illustrator, Affinity) and improve usability for users who customize their shortcuts.
