    Just a Pattern
    69 Posts 8 Posters 61.2k Views 8 Watching
    • L Offline
      Li Xiao @Subpath
      @Subpath
      Great pattern!
      The production method is apparent at first glance.
      I can try to replicate it approximately
      but achieving an exact match will require some additional time and effort.
      0_1718204098829_Pattern.vstyler
      S 1 Reply Last reply Reply Quote 7
        Subpath @Li Xiao
        @Li-Xiao
        Great, well done! πŸ‘
        Yes, it's not really complicated to do and
        I think it mainly lives from the added gradient
        • H Offline
          Harry @Subpath
          @Subpath @Li-Xiao Great pattern! Some tweaks and here we go:
          S 1 Reply Last reply Reply Quote 4
            Subpath @Harry
            @Harry
            nice,
            seems that pattern sparkle some inspiration πŸ™‚
            Btw everybody is pretty welcome with their own variation
              I fed Nodebox with the pattern.
              Here a post of mine about Nodebox
              https://www.vectorstyler.com/forum/topic/4119/a-kind-of-patternnodes-for-windows-free-win-mac
              A while ago I created a Nodebox node tree, with which I can
              replace one object from an SVG file with another. I use this
              to replaced the rectangles from the original pattern with a star.
              Although i think something like this is definitely possible with
              the Repeater. Since it uses symbols.
                Another pattern created with Nodebox and then edited in
                VectorStyler. These two are pretty good companions.
                The Colors where made with VectorStyler's "Colorize" Feature.
                Menu > Effects > Replace Colors > Colorize. I love it πŸ™‚
                Btw. did you know that you can create a Action with it!
                Here is a video that shows the steps creating the first one.
                Here is my first version
                And here the whole thing modified with an
                Offset Shape Effect and the Corner Tool.
                  Repeater Pattern
                  Just a Quader, set Repeater to Concentric
                  and size to Random
                  for Random Coloring
                  Fill your Pattern with a color
                  select it
                  go to Menu > Effects > Replace Colors
                  choose > Colorize
                  use the randomize Feature until you have some
                  coloring you like
                  ( if you found a nice one, "save it as a preset!" )
                  Selecting Tiles of a Pattern/Mosaic is possible this way
                  choose a shape
                  put it over your Pattern
                  select it
                  then select:
                  Menu > Select > Select Others
                  then choose
                  • Select Inside Shapes
                    or
                  • Select Intersecting Shape
                    (thanks to @Li-Xiao for this, did not know this before
                    he mentioned it in a post)
                  I applied a Gaussian blur to the shape and placed it
                  under the pattern selection
                    This pattern is made entirely in VS.
                    The steps are as follows:
                    I made an object with a dashed line
                    and duplicate/transform it.
                    Convert the dashed outline into Paths.
                    Replace the Paths with a Star Shape
                    via Find/Replace in VS.
                    Select Parts of the Pattern with Select inside
                    and recolor it
                    you could also take a look in this thread here:
                    https://www.vectorstyler.com/forum/topic/4565/best-way-to-achieve-this-effect/4
                      Another nice find, made entirely in Vectorstyler
                      with a little help from corner tool and the
                      colorize feature πŸ™‚
                        While i was I looking at this pattern, I had the idea that
                        it might look like a peacock's tail, so I create this one.
                          well, I think you can also see it as a kind of pattern
                          saw this interesting design made with CorelDraw
                          and i recreated it in VectorStyler
                          (Shapebuilder was involved)
                            made a variation, also all in VectorStyler
                              some further variations of this design
                              seems that i am not short on Ideas πŸ™‚
                              will do a tutorial which tricks VectorStyler offers
                              to get such results
                              the first tutorial is online, you found it here:
                              https://www.vectorstyler.com/forum/topic/4624/using-the-extend-path-tool-to-adjust-a-blend
                              this second tutorial shows how to replace dashes of a stroke with another shape
                              https://www.vectorstyler.com/forum/topic/4625/replace-dashed-line-strokes-with-another-shape
                                Another pattern, created in Vectorstyler
                                is an overlay of different patterns and
                                experiments with combined stroke stripes
                                IngolfI 1 Reply Last reply Reply Quote 6
                                  I'm still experimenting with the possibilities Stroke Stripe offers
                                  for creating patterns.
                                  It started with that simple pattern below, I added an offset shape effect
                                  and used Stroke Stripe with Boolean Combine on it.
                                  The Colors were made with Colorize.
                                  To get such patterns from Stroke Stripe it should be closed shapes
                                  and then do a Boolean Combine with it.
                                    Found some new ways for creating Pattern in VS.
                                    You could also take look at this link
                                    https://www.vectorstyler.com/forum/topic/4843/inverted-wave-zig-zag-with-the-outline-zigzag-shape-effect
                                    Here just one Result, but many many Variations
                                    are possible this way
                                      created a, color-wise, somewhat structured version.
                                        A fairly simple pattern, what made it special was
                                        the use of β€œcolorize” with my own palette.
                                        Menu > Effects > Replace colors > Colorize...
                                          another one of my pattern experiments
                                          also colored via colorize like the one above
                                            Working on a Mosaic Project, reusing an old pattern i made,
                                            here a Result. Everything made in VectorStyler. To get slightly
                                            different colors for each mosaic tile "Disturb Colors" was used.
                                            Menu > Effects > Replace Colors > Disturb Colors
