XLS for features and ideas - Mega Thread
White Space Preview: A toggle to turn all text into black blocks. Like so:
Useful when trying to see the document for visual impact.
Visual alignment panel. This is much speedier than the normal iconized alignment options. Providing greater visual feedback. I also think there should be a constraint option baked into alignment. Logically related and sequentially performed. Therefore group tool options.
@Daniel said in XLS for features and ideas - Mega Thread:
The problem with this approach is that it needs a separate "Apply" button. So even if the alignment is just a regular "horizontal-left", you will need 2 clicks to do it. The current approach needs one click only for this.
@VectorStyler: That is true. But as I explained, this is not the only option possible. It is an additional panel alongside the iconized alignment options. And it need not contain the apply button. It can be a simple direct click to apply. Further, having the option to modify click within the panel also reduces cognitive load. I only have to click in one place. Alt click for Horizontal. Ctrl click for vertical. Check this out in XDP to get a feel for it.
Having said that, I think the alignment panel in Inkscape is by far the most advanced and useful of all. If you've not checked it out, highly recommend it.
Also, I reckon there should be a node align panel too.
... Also, I reckon there should be a node align panel too...
You can already align nodes using the alignment tools
and Node Handles too, so i dont see a reason for that
This post is deleted!
@Subpath: Yes, this is not necessary. Agreed.
@monsterfox: Please could you fork this out into a dedicated bug thread. I don't want it to get lost here.
Thank you!
@VectorStyler: Actually, there's a much simpler, more contextual way of doing this. Inkscape got this right. Provide direct, on-screen alignment handles for the the basic and most common alignments. It is exactly similar to aligning text blocks and is very useful.
Spray symbol without calling the tool. Using + number pad when moving a symbol (or group of symbols).
Not clear how this would work. You can insert one or more symbols by dragging from the panel but that will not work as a spray.
Would pressing "+" activate the spray symbol tool?
@VectorStyler: you have created symbols. Now with the select tool active, you make a sequential selection of all your symbols. Then you press escape. Now, when you press + repeatedly, the select tool places the symbols you selected in the same order you selected them. If there's only one symbol, then, that symbol gets stamped. Every time you plus +.
Sort of "insert symbol at the current mouse position" ?
