    • DanielD Offline
      Daniel
      Contextual changes to the colour swatches upon selecting objects. Indicating stroke, fill, and gradient stops.
      • DanielD Offline
        Daniel
        Close all files without saving and return to files, to the current scroll location in each file.
        • DanielD Offline
          Daniel
          Thumbnail view on hover over the files tab. If multiple files are open in VS, allow a thumbnail view on hovering over the tabs.
            VectorStyler @Daniel
            This is not clear: where is the current scroll location ? Is the a "reveal file" type of action?
            • DanielD Offline
              Daniel @VectorStyler
              @VectorStyler: What I mean is, if I am working on multiple untitled files and don't have the time to save it all, then I just want to close the program without a prompt to save. Then when I reopen the program, I want to come back to where I left off. And in each file, I want to be able to find myself in the same zoom level and scroll location. Scroll location might be confusing because VS does artboards and not pages. Think of a multipage document and you're on page 15. You close and come back to the exact same spot. Every time. In VS's case, this does not apply. You just need to come back to the same artboard and zoom level.
              If I have 5 documents, and on document 1, you have three artboards, and you're zoomed into 1500% on an object on artboard 3. Then, when I close and come back, I want to come back to the same place, where I left off. I want to have this in each of the 5 documents.
              For reference, see XDP.
              If you're as disorganised as I am, this is makes life so much better.
              Alternatively, as an addition, there should be a simple tick box within the save prompt window, to "do the same for all files".
              • DanielD Offline
                Daniel
                White Space Preview: A toggle to turn all text into black blocks. Like so:
                Useful when trying to see the document for visual impact.
                • DanielD Offline
                  Daniel
                  Visual alignment panel. This is much speedier than the normal iconized alignment options. Providing greater visual feedback. I also think there should be a constraint option baked into alignment. Logically related and sequentially performed. Therefore group tool options.
                    The problem with this approach is that it needs a separate "Apply" button. So even if the alignment is just a regular "horizontal-left", you will need 2 clicks to do it. The current approach needs one click only for this.
                    DanielD 2 Replies Last reply Reply Quote 1
                    • DanielD Offline
                      @VectorStyler: That is true. But as I explained, this is not the only option possible. It is an additional panel alongside the iconized alignment options. And it need not contain the apply button. It can be a simple direct click to apply. Further, having the option to modify click within the panel also reduces cognitive load. I only have to click in one place. Alt click for Horizontal. Ctrl click for vertical. Check this out in XDP to get a feel for it. 🙂
                      Having said that, I think the alignment panel in Inkscape is by far the most advanced and useful of all. If you've not checked it out, highly recommend it.
                      Also, I reckon there should be a node align panel too.
                      S M 2 Replies Last reply Reply Quote 1
                        Subpath @Daniel
                        @Daniel
                        ... Also, I reckon there should be a node align panel too...
                        You can already align nodes using the alignment tools
                        and Node Handles too, so i dont see a reason for that
                        here a video example
                        • M Online
                          monsterfox @Daniel
                          This post is deleted!
                          • DanielD Offline
                            Daniel @Subpath
                            @Subpath: Yes, this is not necessary. Agreed.
                            • DanielD Offline
                              Daniel @monsterfox
                              @monsterfox: Please could you fork this out into a dedicated bug thread. I don't want it to get lost here.
                              🙂 Thank you!
                              • DanielD Offline
                                @VectorStyler: Actually, there's a much simpler, more contextual way of doing this. Inkscape got this right. Provide direct, on-screen alignment handles for the the basic and most common alignments. It is exactly similar to aligning text blocks and is very useful.
                                • DanielD Offline
                                  Daniel
                                  Spray symbol without calling the tool. Using + number pad when moving a symbol (or group of symbols).
                                    Not clear how this would work. You can insert one or more symbols by dragging from the panel but that will not work as a spray.
                                    Would pressing "+" activate the spray symbol tool?
                                    • DanielD Offline
                                      @VectorStyler: you have created symbols. Now with the select tool active, you make a sequential selection of all your symbols. Then you press escape. Now, when you press + repeatedly, the select tool places the symbols you selected in the same order you selected them. If there's only one symbol, then, that symbol gets stamped. Every time you plus +.
                                        Sort of "insert symbol at the current mouse position" ?
                                        • DanielD Offline
                                          @VectorStyler I'll explain this much more clearly tomorrow.
                                          • debraspicherD Offline
                                            debraspicher @VectorStyler
                                            @VectorStyler I've used "Continuous Export" for working on themes or templates in Affinity that have a lot of moving parts. Assets that need to be uploaded in either chunk form or .zips.
                                            While useful, it's not critical (well, not always...). I'd say its more for UI people or web designers. It's just more that the Export functions are hidden by another Persona, so having to avoid tabbing is beneficial instead of scrolling through a very lengthy list to export single items. Meanwhile I can go quickly test something I've exported once I've made a change. I don't think the way they implemented it is efficient though. It shouldn't be instantaneous as it has caused hangs. But for the most part, seems to work fine.
                                            Edit: The other consideration, if that user has a template/theme they are working on but it's multiple parts for a particular element, that element involving many parts may need all updated at once. So having this process streamlined makes pushing to production side (running on local system, FTP, etc) and previewing more straightforward.
                                            32GB RAM @ 6000MHz
