Erase block still not erasing only selected shape
 @VectorStyler said in update 1.2.030: Erase block modifier to work on selected shapes only. Using the new build (30) this does not seem to be fixed. Here is a video showing this
 @Boldline Was is selected in the Context panel in the Source drop down?
 @VectorStyler That was the issue - thank you!
 @VectorStyler I really like the option in the contextual menu to be able to choose between selection/layer/canvas (now that I know to check there first!) What about adding an option for same-style?
 @Boldline said in Erase block still not erasing only selected shape: What about adding an option for same-style? The problem is identifying the style. Could be the current color, but that will handle solid fills only.
