Just a Pattern
 Working on a Mosaic Project, reusing an old pattern i made,
 here a Result. Everything made in VectorStyler. To get slightly
 different colors for each mosaic tile "Disturb Colors" was used.
 Menu > Effects > Replace Colors > Disturb Colors
 played with randomness Was playing with randomize in the Repeater using just a quad.
 Did a Boolean "Dividide" with the Result, then a "Offset Path" Shape Effect
 " Inner Offset" and at least i use "Colorize" with a Color Palette i made.
 Someone said the previous picture looked like a collection
 of Polaroid photos, so I made a version like that too.
 This was made with the help of Actions (Vectorstyler Macros)
 to get the Polaroid look.
 Continued a bit with my mosaic project.
 I had the idea of a kind of natural looking color gradient for mosaics.
 The "Color Disturb" function was no help because of the gradient required.Instead, I created a duplicate version, colored it using "Colorize"
 using my palette and made it transparent (20%). I placed it over
 the gradient, which creates nice, slightly differently colored tiles.
 @Subpath said in Just a Pattern: Another pattern, created in Vectorstyler
 is an overlay of different patterns and
 experiments with combined stroke stripes
  This one looks truly elegant and aesthetically pleasing.
 thank you, i like that too.
 Been playing around with some lines/paths
 and decided to try a mosaic with them.Made two paths and a blend between them
 the deformation was made in CorelDraw because
 they look better, but VectorStyler wants to improve
 the deformation toolsThe rest are made in VectorStyler.
 These are three times the same paths/shapes (layered)
 one for the fill, one for the mosaic and one for the transparent
 and randomly colored mosaic to give it a little more life
 While browsing through old things I've made, I found this
 variation of the blue floral pattern I posted above.
 @Subpath said in Just a Pattern: Made two paths and a blend between them
 and randomly colored mosaic to give it a little more lifeInteresting pattern - it reminds me of a cobbled pavement. In this case "the stones" shouldn't overlap  - example - example
 Thanks, you're actually on the right track
 The pattern you mentioned is one of several experiments that
 should ultimately led to something like a cobblestone/mosaic.My goal was to figure out a way how to create something like
 that in Vectorstyler. I'm still experimenting a bit, but when
 everything will fall together, I'll post a tutorial.
 @Li-Xiao created a few designs in this thread
 https://www.vectorstyler.com/forum/topic/5140/patterns-generated-with-node-bump-effectI couldn't resist taking one and trying out Colorize.
 Here the needed StepsSelect the Design
 Expand Appearence
 Ungroup the DesignDo a Boolean Divide Fill the Result, color doesnt matter
 (colorize work on filled objects only)Call Colorize Call Colorize Options
 deselect "Change Strokes"Choose a Palette/or some Colors
 ( you can create your own Palette
 or select some colors using the
 system palette )
 You could also color only the Strokes if you like.
 Here another one
 @Subpath Very beautiful  , I also really enjoy using Colorize. , I also really enjoy using Colorize.
 Metaball try made in VectorStyler
 @Subpath Cool !
 @Devil-Dinosaur, thank you Indeed.
 Will do a little Tutorial and show a few Tricks.
 Some optical illusion, i made a while ago.
 The base was simple a yellow stroke where i place a pattern Brush
 in the same size above and the copy scale and rotate it.Here the Base
 Here the Pattern
 Another interesting optical illusion.
 Made in VectorStyler and Black InkVectorStyler
 Dashed Lines, random colorized, the whole thing copied, and
 two copies placed underneath, each with a Gaussian blur image effectBlack Ink
 Only for Symmetry, because of its symmetry Fusion Feature.
