    Just a Pattern
    47 Posts 7 Posters 61.0k Views 7 Watching
      made a variation, also all in VectorStyler
        some further variations of this design
        seems that i am not short on Ideas πŸ™‚
        will do a tutorial which tricks VectorStyler offers
        to get such results
        the first tutorial is online, you found it here:
        https://www.vectorstyler.com/forum/topic/4624/using-the-extend-path-tool-to-adjust-a-blend
        this second tutorial shows how to replace dashes of a stroke with another shape
        https://www.vectorstyler.com/forum/topic/4625/replace-dashed-line-strokes-with-another-shape
          Another pattern, created in Vectorstyler
          is an overlay of different patterns and
          experiments with combined stroke stripes
          IngolfI 1 Reply Last reply Reply Quote 6
            I'm still experimenting with the possibilities Stroke Stripe offers
            for creating patterns.
            It started with that simple pattern below, I added an offset shape effect
            and used Stroke Stripe with Boolean Combine on it.
            The Colors were made with Colorize.
            To get such patterns from Stroke Stripe it should be closed shapes
            and then do a Boolean Combine with it.
              Found some new ways for creating Pattern in VS.
              You could also take look at this link
              https://www.vectorstyler.com/forum/topic/4843/inverted-wave-zig-zag-with-the-outline-zigzag-shape-effect
              Here just one Result, but many many Variations
              are possible this way
                created a, color-wise, somewhat structured version.
                  A fairly simple pattern, what made it special was
                  the use of β€œcolorize” with my own palette.
                  Menu > Effects > Replace colors > Colorize...
                    another one of my pattern experiments
                    also colored via colorize like the one above
                      Working on a Mosaic Project, reusing an old pattern i made,
                      here a Result. Everything made in VectorStyler. To get slightly
                      different colors for each mosaic tile "Disturb Colors" was used.
                      Menu > Effects > Replace Colors > Disturb Colors
                        played with randomness
                        Was playing with randomize in the Repeater using just a quad.
                        Did a Boolean "Dividide" with the Result, then a "Offset Path" Shape Effect
                        " Inner Offset" and at least i use "Colorize" with a Color Palette i made.
                          Someone said the previous picture looked like a collection
                          of Polaroid photos, so I made a version like that too.
                          This was made with the help of Actions (Vectorstyler Macros)
                          to get the Polaroid look.
                            Continued a bit with my mosaic project.
                            I had the idea of ​​a kind of natural looking color gradient for mosaics.
                            The "Color Disturb" function was no help because of the gradient required.
                            Instead, I created a duplicate version, colored it using "Colorize"
                            using my palette and made it transparent (20%). I placed it over
                            the gradient, which creates nice, slightly differently colored tiles.
                              Ingolf @Subpath
                              @Subpath said in Just a Pattern:
                              This one looks truly elegant and aesthetically pleasing.
                                Subpath @Ingolf
                                @Ingolf
                                thank you, i like that too.
                                  Been playing around with some lines/paths
                                  and decided to try a mosaic with them.
                                  Made two paths and a blend between them
                                  the deformation was made in CorelDraw because
                                  they look better, but VectorStyler wants to improve
                                  the deformation tools
                                  The rest are made in VectorStyler.
                                  These are three times the same paths/shapes (layered)
                                  one for the fill, one for the mosaic and one for the transparent
                                  and randomly colored mosaic to give it a little more life
                                    While browsing through old things I've made, I found this
                                    variation of the blue floral pattern I posted above.
                                    • H Online
                                      Harry @Subpath
                                      Interesting pattern - it reminds me of a cobbled pavement. In this case "the stones" shouldn't overlap πŸ™‚ - example
                                        Subpath @Harry
                                        @Harry
                                        Thanks, you're actually on the right track πŸ™‚
                                        The pattern you mentioned is one of several experiments that
                                        should ultimately led to something like a cobblestone/mosaic.
                                        My goal was to figure out a way how to create something like
                                        that in Vectorstyler. I'm still experimenting a bit, but when
                                        everything will fall together, I'll post a tutorial.
                                          @Li-Xiao created a few designs in this thread
                                          https://www.vectorstyler.com/forum/topic/5140/patterns-generated-with-node-bump-effect
                                          I couldn't resist taking one and trying out Colorize.
                                          Here the needed Steps
                                          Select the Design
                                          Expand Appearence
                                          Ungroup the Design
                                          Do a Boolean Divide
                                          Fill the Result, color doesnt matter
                                          (colorize work on filled objects only)
                                          Call Colorize
                                          Call Colorize Options
                                          deselect "Change Strokes"
                                          Choose a Palette/or some Colors
                                          ( you can create your own Palette
                                          or select some colors using the
                                          system palette )
                                          You could also color only the Strokes if you like.
                                          Here another one
                                          • L Offline
                                            Li Xiao @Subpath
                                            @Subpath Very beautiful πŸ‘ , I also really enjoy using Colorize.
