Laggy update of Color Picker in Context Bar on Windows
Very laggy update of live color preview when I drag the sliders to adjust a Swatch. Doesn't matter if it is Fill or Stroke.
https://1drv.ms/v/s!AuWHX0h5bAoRifxo_8e0hOcLMguiyA?e=iJu3dd
Color {Panel} works fine though. I think it could be a little smoother, but it's not bad:
@debraspicher Yes, there is a lag here also on Windows. I will try to improve this.
BTW: there will be a small lag in any case, as the panel update is a bit delayed by design (for any panel).
The color picker in the Context Bar updates beautifully now. In fact, I think it is buttery smooth now compared to the one in the Color Panel. There's a slow update of the Object in comparison when dragging sliders in the Color Panel version, as in there is a bit of a delay. Whereas, the Context Bar is moving with the slider in real time. Regardless, everything is much more usable and I appreciate these updates you are making. So thanks for that.
Color Picker in the Context Bar has a tendency to change the position of a Hue (moving only on a rectangle area), I would like to change the hue myself. Also, I can't reach for the whole color spectrum compared to Color panel - video
