Shape Paint irregularities
I sometimes come across odd behaviours with some Shape Paint artwork. I have attached example files.
The original file is Shape paint test file A
I used Save As to save Shape paint test file BOpen the files and try to move the artwork around. Notice the different behaviours? I am forced to refresh in both instances in order see the actual colours.
Note that I used default settings.
VS 1.2.024
1_1715940488484_Shape paint test file B.vstyler 0_1715940488476_Shape paint test file A.vstyler
@William-Kansepa Thanks for the example file. I will try to fix this for the next build.
So far so good in VS 1.2.0.25. The Shape Paint objects are updating perfectly after transforming.
Thank you @VectorStyler!
