VS 1.1.101 - can't click File tab
As in the topic, I have to click the Edit tab first.
Moreover, I can't click the "Velocity" option in the Pressure drop-down menu for the Pencil and Brush tools.
I have the same problems.
Maybe related, the close button needs several clicks before VS actually closes. I noticed the cursor changes to a double arrow when I hover over it (Windows 11)
@Harry Cannot replicate it here (Windows 10).
Does the "File" menu get a highlight (grey) when hovering over it?Is there screen scaling in the Windows display settings?
@VectorStyler said in VS 1.1.101 - can't click File tab:
Does the "File" menu get a highlight (grey) when hovering over it?Yes, it is highlighted, but it doesn't respond to a click. You have to click on for example Edit tab first - Record it
In this video I'm trying to click on File and Velocity options.
Yes - it is set to 125%, but I checked also without scaling and the problem is the same.
@Gremriel said in VS 1.1.101 - can't click File tab:
I have no such problems
I discovered that every icon under the "File" tab vertically cannot be clicked - Record it
I moved back to VS 1.1.100 for now; there are no such issues.
@Harry I opened a bug on this one and will try to replicate and fix it ASAP.
File "tab"!? No wonder I didn't find it...
