Composite shape will move after "Intersect" mode selection
- Create a composite shape and select "Combine" for their mode.
- In the Context toolbar select "Intersect" from the Mode popup.
- Now select another mode, eg Open Union. The composite shape will move at this point. It should prolly stay in the same location.
Video:
https://www.youtube.com/watch?v=8rrlRazhXuoVS 1.1.096
@pentool I will try to replicate this.
@pentool I could not replicate this by repeating the steps from the video.
Would it be possible to send that vstyler file to me, at around the 1:00 minute mark just before changing the combine mode.
@VectorStyler Well, the Composite Shape tool is definitely glitchy because now when you select "Intersect" mode the entire shape disappears from the artboard. If you zoom out very far it's not even visible anywhere, not even the selection box - even though in the Layers panel you can see it's selected.
Video
https://www.youtube.com/watch?v=FcydKbFRDpEFile
0_1691256509401_composite-shape.vstylerSetting + Workspace:
https://www.dropbox.com/scl/fi/8xnqx9f1xaom7eqgqo7ec/VS-settings-workspace_202308051730.zip?rlkey=q8umdggzkntl4krd4g5z9309f&dl=0VS 1.1.097
PS: Is it possible to enable either zip or xml file uploads here? It would be way easier as opposed to uploading the document here and the settings to somewhere else.
@pentool said in Composite shape will move after "Intersect" mode selection:
I added the file types, let me know if uploading works.
Yay! Beautiful! Thank you!
