Presets Panel > Display submenu loses its selection (checkmark)
  • The Presets Panel > Display submenu loses its selection (checkmark) when you select a different size display from the Presets Panel Options dialog. For "List" display, no checkmarks shown for any size selection (small, medium, large).
    1. Open the Presets Panel (Panels > Presets > Presets)
    2. In the Presets panel's Display menu (for me) currently the "Small Grid" option is selected. There's a checkmark next to Presets Panel > Panel Menu > Display > Small Grid.
    3. Select "Panel Options..." from the Presets Panel's menu.
    4. In the Panel Options dialog, for Size, select the predefined value "Large" from the dropdown. For "View", make sure "Grid" is selected. Close the Panel Options dialog.
    5. Now head over to the Presets panel's menu, and look at the Display submenu. The checkmarks (selection) has disappeared for the selected size (Large Grid).
    6. Repeat the process, but now select "List" in the Preset Options panel for "View". In this case regardless which preset view size you select (small, medium, green), none of them will reflect the selection in the Presets Panel's Display menu.
    Video here:
    https://www.youtube.com/watch?v=2fK8UWMM1uU
    VS 1.1.094
    @pentool Yes, replicated here also. Looks like the value for "Large" is different in the menu. Will be fixed ASAP.
