Shape Paint Tool crashed the app
Just submitted a crash report (via the dialog). I was playing around with the Shape Paint Tool coloring shapes when the app crashed. If you are interested in the crash dump, I can send it to an email. Unfortunately I can't seem to be able to upload it here.
This is how you crash Shape Painter (see video link at the end):
- Create a new document.
- Select the "Super Shape" shape and draw an object with it. It will possibly work with other shapes but this is the shape I've used.
- Select Object > Transform > Transform
- For "Apply To" select "Clone"
- For the transform origin, select the middle dot on the right.
- For the Angle, select -60 or so degrees
- For Repeat, select 5. Click OK.
- Select the original object and select Object > Convert to Curves.
- With the Shape Editor Tool selected, drag and change some of the nodes of the original object.
- Select all the objects (original + the clones) and select Object > Convert to Curves.
- With all the objects still selected, select Styles > Shape Paint > Create Shape Paint
- Select the Shape Paint Tool and drag over selected areas to color them. Repeat a few times, adjusting the color as needed.
- Make sure all objects are selected and do Edit > Delete (or just use the delete key on your keyboard).
The app has crashed.
Video here:
https://www.youtube.com/watch?v=fv7sgs87H_I
The Shape Paint Tool seems to have a Bug.
What Shape doesnt matter, had the same disappearing then you.
Did not use it until crash.The Shape Builder Tool will work, you could take that as an alternative.
@pentool Replicated here also. There are several problems when using clones inside shape paint objects.
