Transform Pivot Broken ?
For some reason, I just cannot edit the transform pivot location on an object. I have 'enable transform pivot editing' selected in the context panel and the pivot point on a selected object highlights when it is selected, but I cannot find any way to actually move the pivot point ?
As soon as you attempt to move the point, it just disappears and deselects the object ??
The manual suggests hovering over that point and that it should then allow moving, but it doesn't.Any thoughts ? No doubt there will be an element of stupidity on my part
TIA
Neil
UPDATE: Would it have helped if I had 'adjusted transform pivot' enabled in the prefs do you think - DOH
Sometimes I think that that we can have too many prefs - surely just the check icon on the context panel is sufficient ???????
@Igull said in Transform Pivot Broken ?:
Yes, that is the one.
