Bug Report & Improvement Request: Space/Dash Menu Mapping and ZENKAKU Space
@861475_VctSt said in Bug Report & Improvement Request: Space/Dash Menu Mapping and ZENKAKU Space:
Chronic Issue with Space Character Input via Japanese Keyboard
There is a chronic bug regarding space input from the keyboard when using the Japanese input method (Kana-Kanji conversion / IME). Normally, the following standard codes should be inputted depending on the key operation, but currently, VectorStyler inputs a completely different space character.When typing a Half-width space key: U+0020 (U+100001 false)
When typing a Full-width space key: U+3000 (U+100001 false)What font is selected when typing these with the IME input method?
I used "Hiragino Sans GB" hoping it would be a versatile choice to easily share the test results, but as you rightly suspected, it is an OS system font. I apologize for overcomplicating the matter.
I have run the test again using other standard fonts typically used in Japanese DTP.
As a result, the inputted code wasU+0020, and it successfully displayed as a HANKAKU (half-width) space on the screen.To be honest, this space-related behavior is a chronic issue in VectorStyler. I have actually mentioned it in another post in the past.
However, out of concern that it might be a complex issue affecting the core architecture of the software, I have refrained from pressing the matter too strongly, treating it as a niche request specific to East Asian users. -
It is not a complex issue: the only thing needed is that the font has the half width space and that I know how to input that.
The technical part is easy, I just need help with the Japanese part
I have put together a summary of the most basic typing operations that every Japanese user does naturally.
Here are the fundamental rules for how Japanese Mac users differentiate between typing a "Half-width space (U+0020)" and a "ZENKAKU (Full-width) space (U+3000)":-
To input a Half-width space:
First, press the "英数 (Alphanumeric)" key, and then press the "Space" key.
As a result, a "Half-width space (U+0020)" is inputted. -
To input a ZENKAKU (Full-width) space:
First, press the "カナ (KANA)" key, and then press the "Space" key.
As a result, a "ZENKAKU space (U+3000)" is inputted.
Currently in VectorStyler, it seems that when we perform these key operations, the software does not correctly receive the
U+3000orU+0020sent by the OS, and instead converts it into a different, unintended space character. I believe this is the root of the problem.Does this explanation help solve the puzzle for the implementation? Please let me know if you need any other information about the Japanese environment!
Best regards,
Yes, this helps a lot!
What input method is selected in the MacOS menu (right side of the screen), when using Japanese input with your keyboard?
I only have international physical keyboard, and I try to replicate this with the "Japanese - Kana" input method:
With regular "Space" key I get U+0020
With regular "Option+Space" key I get U+3000I will try to find a Japanese keyboard
And one more thing:
Create a vstyler file with the following:
- a shape text with some text and the "Half-width space (U+0020)" as VectorStyler inputs it
- other shape text with some text and the "ZENKAKU space (U+3000)" as VectorStyler inputs it
and send me the file.
I want to check what action character codes are input
This post is deleted! -
@VectorStyler said in Bug Report & Improvement Request: Space/Dash Menu Mapping and ZENKAKU Space:
I have sent it via email.
However, I do not think this is the result you were hoping for. After all, this is precisely the heart of the problem.
I attempted the input using a total of four different methods, including this one.
I hope at least one of them proves helpful to you. -
@861475_VctSt Got it!
ver. 1.3.022–1.3.023: Handled via email correspondence.
ver. 1.3.024
Follow-up report regarding two issues.
I will refrain from offering my own analysis of the causes (as I am not a programmer).
Note: The character code identification is based on the VS glyph palette.- Localization: Translation error
- Space character input
u3000 (ZENKAKU Space; Ideographic-Space): Input result is U+2003.
u0020 (HANKAKU-Space; Space): Input result displays as u100001 (Supplementary Private Use Area-B).
@861475_VctSt I will try to thix these.
Can you send me the translation errors as text, not image? Thanks!
I’m prone to making mistakes myself, so I’ll double-check everything and send it to you later.
Ver. 1.3.027
In my previous posts, I reported multiple issues together that should ideally be addressed separately. To avoid confusion, please let me organize the current situation.
The two issues I raised are as follows:A) Text > Insert Character: Japanese localization (translation) errors
B) Spaces during Japanese (Kana-Kanji conversion) input: Issues with half-width and full-width space input[Current Status]
A) Resolved (ver. 1.3.026) - Thank you for fixing this.
B) Unresolved (ver. 1.3.027)Additionally, regarding the character insertion from the menu (A), a new issue, "Issue A-1", has been found. The details are as follows:
[Details of Issue B (Unresolved)]
Current Bug:- When typing a half-width space on the keyboard, it does not become half-width. When checking the Glyph palette, it shows an abnormal code of "U+100001".
- When typing a full-width space on the keyboard, it visually appears as full-width, but the Glyph palette shows it as "U+2003 (EM Space)".
Expected Result:
- Half-width space = Space (U+0020)
- Full-width space = Ideographic Space (U+3000)
[Details of Issue A-1 (New)]
When inserting a space from the menu, the visual result on the screen is fine, but checking it in the VS Glyph palette reveals that the internal code seems incorrect.Current Bug:
- En Space: Displayed as "U+0000"
- Em Space (Kuwata): Displayed as "U+0000"
Expected Result:
- En Space = U+2000
- Em Space (Kuwata) = U+2001
[Proposal for Future Development]
Since I am not a programmer, I can only report the results I see on the screen. I have provided materials so far, but I assume that providing information solely from a user level might not be enough to reach a fundamental solution.If digging deeper into the specific requirements of the Japanese environment risks causing regressions or degrading other features, and becomes an obstacle to the overall development of VectorStyler, I believe it is a reasonable option to put this complex issue (such as the U+3000 problem) on hold for now and treat it as a "Known Issue".
However, even in that case, there is one top priority that I would like you to fix at the very least.
That is problem [Issue B - 1].
If we can just correctly input a standard "half-width space (U+0020)" from the keyboard, we will be able to proceed with our work for the time being.This is a proposal meant to avoid hindering the overall development progress of VectorStyler. Please consider this in light of the current situation.
@861475_VctSt Added some diagnostic for analyzing these issues.
More info in email.
I have sent the results.
Best regards. -
ver. 1.3.028
Thank you for this absolutely fantastic update!I have confirmed in Build 1.3.028 that the issues with the following codes have all been resolved as far as the VS Glyph palette is concerned:
- Keyboard input: U+0020, U+3000
- Menu input: U+2000, 2001, 2002, 2003, 2004, 2005, 2006
In particular, the fact that a Full-width space (U+3000) can now be inputted correctly via the Japanese Kana-Kanji conversion keyboard is a groundbreaking milestone for the Japanese environment. It has been over five years since the beta testing days. My long-held wish has finally been fulfilled, and I am deeply moved.
Users from other language regions might think, "It's just a space, why exaggerate?" However, in Japanese typography, a space is not merely a gap between characters; it is an absolute structural component that controls the framework of the layout, including justification. If the internal recognition of the space character is even slightly off, beautiful typesetting (Mojigumi) and spacing (Mojitsume) become entirely impossible.
That is exactly why this fundamental resolution is such a massive step forward for the advanced DTP capabilities of VectorStyler in the future.
I sincerely appreciate the brilliant work and the patience of the development team who saw this through to the end over these many years.
@861475_VctSt The text formatting issue should be fixed now.
Regressions related to this issue occurred in versions 027 through 030.
These have been fixed in version 031.
The issues, including the one involving full-width spaces, have been resolved, making the software even easier to use.Thank you.
P.S.
I believe the basic functions for Mojigumi and Mojitsume are currently working without any issues.
However, regarding the finer details and advanced settings, I lack the specialized knowledge and analytical skills to rigorously test and evaluate them, so I will refrain from making a definitive judgment at this time. Therefore, my personal assessment right now is that these features are "just one step away from completion."
I look forward to continuing to monitor how these features evolve in the future.
