Queries Regarding VectorStyler 1.3
@VectorStyler Will a halftone effect with dot merging be added to the halftone panel in the future?
@monsterfox said in Queries Regarding VectorStyler 1.3:
In the case of the first image of this thread:
The problem is not with dot merging, but with the shape of the halftone. Those halftones (first image) are created in postscript as images. So this exact case will not be added to the halftone panel.The second image from this thread might be possible, I have this in the backlog and will try to add it as soon as possible.
@VectorStyler After upgrading to version 1.3, the program's running speed has been significantly improved compared to version 1.2, but occasional lag issues still occur. This file is a typical example—the extremely large number of nodes in the graphic causes lag when moving objects. I have tested the object-moving function in several programs: Adobe Illustrator runs without any lag; older versions of CorelDRAW have slight lag, while the newer versions suffer from noticeable lag. My primary program at present is FreeHand 9. Despite being released over two decades ago, it still ranks among the most smooth-performing software and shows no lag at all when moving this object. Finally, I tested Inkscape, which has a reputation for lagging. I expected it to be extremely sluggish, but surprisingly, its object-moving speed is even faster than that of VectorStyler.
Therefore, I’m curious about why such lag persists despite the upgrades to both my hardware and software. Could it be that VectorStyler’s lag is attributed to its display enhancement features, while FreeHand 9, which lacks such features, runs faster?
0_1766243159919_卡.zip -
@monsterfox I will add this to the backlog, but not sure if performance can be improved much.
The time is spent on rendering those outlines.
@VectorStyler Is it possible to add a view mode similar to FreeHand’s—one that removes image quality enhancements and prioritizes speed? The existing pixel mode also lags, and sometimes it’s even more laggy than the normal view mode.
I will think of something before the 1.4 release.
@VectorStyler Version 1.3 is already quite robust, and it will only grow more powerful with additional features in the future. I’m used to working efficiently by setting up shortcuts and frequently-used shortcut icons. I’ve already configured and put to use almost all the shortcut keys within the reach of my left hand, but I’ve found that they’re still not enough. Just out of curiosity, can the spacebar function as a modifier key? I know no other programs have implemented this, but I have a feeling it’s technically feasible.
In Windows these keys that input text can cause issues when held down. In these cases, maybe the best is to press/release to flip an option, but that will conflict with shortcuts.
The new build contains some stoke rendering speed improvements, let me know if this is better on your machine also.
@VectorStyler I tested the file I provided, but it still lags. It seems that the improvement is not significant.
@VectorStyler Following LIXIAO's suggestion today, I turned off the "Show Nodes on Hover" option under Preferences > Selection, then tested moving objects. There was still some lag, but it was noticeably faster than before.
@VectorStyler I encountered a halftone graphic similar to the one in Floor 13 of this thread again today. I know that the repeater function has been enhanced in previous versions, but I'm not sure if such graphics can be created now. If it is supported, could you provide a video demonstration?
@monsterfox Which graphics is that ?
@VectorStyler The original image is a print on a piece of material, which is quite blurry, but the general effect is like this. The difference is that the smallest shapes are rectangles with no tilt at all, while the largest ones are tilted.
It’s easy to create a single strip using the blend effect, but repeating this process and ensuring global coordination is rather cumbersome. If the repeater could support tilt adjustments for both the smallest and largest shapes, this kind of graphic could be created. If possible, please add the rotation adjustment function as well.
This can be done with a number variable for the tilt amount and then controlling the variable using the backdrop intensity as a repeater adjustment
not sure if i understand you right
dont know what the tilt meanmean you something like this ?
then repeater > addional options > Adjustment Geometrys > Edit Adjustment
may be a way
@Subpath The effect is very similar to the one in your image above, but yours looks more like rotation rather than tilt.
@VectorStyler Could you provide an operation demonstration,Thank you。
ok,
had a closer look at your pic
seems that Tilt is the same like "Skew" in Repeater
forgot the repeater settings
here the pic
