    Bug List for Version 1.3
    107 Posts 4 Posters 18.4k Views 4 Watching
      monsterfox @VectorStyler
      @VectorStyler This is another blend failure error—the two shapes in the file cannot be blended. The file in question is a preset template I created from scratch. After consulting with Li Xiao, I confirmed that he can execute the blend operation without issues in a file he newly created. I suspect this problem is caused by a conflict with my custom styles and would appreciate a resolution to fix it.0_1765896294861_33 (1).vstyler
        monsterfox @Subpath
        @Subpath Oh right, I do know how to set up an Action—it’s just a terminology habit. That’s why the term "macro" sounds unfamiliar to me, but they’re actually the same thing.
          VectorStyler @monsterfox
          I managed to replicate the first issue (from the video).
          I do not have the exact shape for the second error from the video.
            Subpath @monsterfox
            @monsterfox
            ....it’s just a terminology habit...
            Seems so, maybe there are some minor differences sometimes ?
            As i know extern (standalone Macro recorders) useful when a program
            have no Macro/Action recording, but i never heard of a extern Action
            Recorder.
              monsterfox @Subpath
              @Subpath What I know is that macros can record the coordinate positions of operations, but the current actions don’t support this—they can only record the sequence of some regular operations. However, I think macros are basically useless in VectorStyler , because in the process of drawing graphics, you almost never encounter situations where you need to operate with the same coordinates. So the current actions should be more than sufficient.
                Subpath @monsterfox
                @monsterfox
                Aside from that design may on a different position, there are definitely cases
                where precise mouse positioning is useful. For example, with menus, which
                are usually located in the same position.
                The actions in VS are sufficient in many cases, but unfortunately
                too limiting for me, as they don't support some commands.
                The macro recorder in CorelDraw was on a completely different level.
                Because the recorded steps were are converted into Visual Basic
                commands, allowing for to be edited after recording to insert loops or
                additional commands.
                In one of my jobs, I frequently used the standalone tool "AutoIt," which also
                allows for precise mouse positioning. The manufacturer's specific vector
                graphics/printing program didn't have any actions or macros. "AutoIt" is a
                well known Windows Tool for automating Tasks in App which didnt have
                a Action/Makro recorder.
                With this, I was able to automate many tasks, such as creating numerous
                DIN vector graphics symbols in various sizes. Doing this manually would
                have taken weeks. (DIN is a german Norm, in this case for Symbols)
                Unfortunately, VS doesn't follow Windows conventions sometimes in this
                regard, so it is not possible to use AutoIt in it. I think that when scripting is
                introduced (it's on the roadmap), the possibilities will expand in a way
                where I would be happier with.
                  I've set the shortcut for copying an object's size to Alt+C and pasting the object's size to Alt+V. Draw any two shapes (A and B) of different sizes. When copying the size of A and pasting it to B, two errors occur:
                  1. Error 1: After applying A's size to B, B retains its original size—meaning two instances of B are now generated (this is incorrect).
                  2. Error 2: Adding the "Copy Object Size" and "Paste Object Size" tools to the toolbar makes them unusable. I’m not sure if this conflicts with my existing shortcuts (preventing them from appearing simultaneously), but the shortcuts themselves also fail to work.
                  It’s worth noting that using this feature directly through the menu works normally. I hope this issue can be resolved.
                    @monsterfox I opened a bug on this
                      @VectorStyler The issue with Error 7 remains unresolved
                        When using the Path Offset effect, an error occurs when modifying the offset parameter in the Width Panel: for example, if you input 2mm, the actual offset is only 1mm. This error arises because the Width Tool and the Contour Path Tool adopt the same offset mode (offset on both sides).
                        I will try to replicate this.
                        • EvaeloE Offline
                          Evaelo
                          Gradients no longer work. Updated to v1.3.004 64bit, Windows 10 Pro.
                          alt text
                          I just checked that only the 'Noise' type of gradient actually worked. Really odd… so most likely we got a bug.
                            VectorStyler @Evaelo
                            @Evaelo Send me that file and Il will try to replicate it here.
                            In Settings -> Performance, try Software for the Compute engine.
                            EvaeloE M 2 Replies Last reply Reply Quote 0
                            • EvaeloE Offline
                              Evaelo @VectorStyler
                              As you command:
                              0_1766926041465_Gradient is broken.vstyler
                                @VectorStyler https://youtu.be/Ax06GN5JwRg?feature=shared[0_1766927882644_合.vstyler](/forum/assets/uploads/files/1766927888679-合.vstyler)
                                16.File Vulnerability Compilation & Fix Requests
                                1. When multiple objects are selected and the Move Transform tool is used with the Transform Each option enabled, an error occurs: the sorting order of the graphics becomes chaotic instead of arranging from large to small.
                                2. Text input is unavailable within the file.
                                3. The Stroke Tool fails to work, and the corresponding stroke panel is also non-functional.
                                4. There are numerous broken paths in the file. If all graphics are selected and the Join Overlapping Nodes function is applied, some graphics will be duplicated in their original positions.
                                5. When two shapes are merged with overlapping areas, converting the merged shape to a rectangle will result in an unexpected positional offset of the generated rectangle.
                                We sincerely hope these issues can be fixed in subsequent updates.
                                VectorStylerV 3 Replies Last reply Reply Quote 1
                                  @monsterfox I added these to the backlog.
                                    The sorting order is the order of selection. In case of box selection, this is the stacking order of objects.
                                      The text in the file was converted to curves
                                        @VectorStyler 17,When selecting multiple objects by holding down the Shift key, clicking on an empty area will deselect all objects .
                                          I will fix this
                                            @VectorStyler In 2025.12.11.23:33 the error of incorrect scaling when importing the two DXF files contained in the compressed package I provided into the program has not been fixed yet. It is hoped that this issue can be resolved.
