[ Text on Path]The offset value does not change to the opposite when the path direction is changed.
As in the title. For both texts the offset value is 10mm. However, in one case the text is below the path and in the other above.
@encart The way the text offset works is that the original pat is offset by the given amount and then the text is placed one or the other side of that offset.
