Text Frame Option - Baseline
From the "Text frame option panel", selecting a baseline does not make it appear. You have to change a value below to view it:
@Pat I added this to the backlog, will be fixed ASAP.
@VectorStyler I'm also wondering if it would be possible to activate the use of the baseline from this panel without having to go to the paragraph panel options?
@Pat No such option in this view. Aligning text to baselines is a paragraph option.
Should there be one in the text frame options view also?
@VectorStyler It would be nice indeed, because that's the advantage of being able to preview the effects of options. If this isn't already activated in the paragraph panel options, then you need to leave the text frame options and return to preview different values.
