beta 1.2.011
    VectorStyler 1.2.011 release notes
    • Multiple blend improvements and bug fixes.
    • Show references also when searching for styles.
    • Selecting a file in Open Recent should activate document if already opened.
    • Copy - pasting objects from inside moved layers.
    • Improved reference style handling.
    • Copy - pasting objects containing references should handle the reference links correctly.
    • Fixed possible crash when using Performance sections of the Settings view.
    • Fixed a bug in the color and style picker tools.
    • Confirm yes/no alerts with the return key.
    • Correct arrow direction on outlines with retracted handles.
    • Snapping in Pen tool when holding the Space key.
    • External palette to highlight the color of the selected object.
    • Creating new character and paragraph styles should keep the base style link intact.
    • Proportional mode button in shape options view.
    • Scale the character leading with the text.
    • Improved PDF exporting of certain fonts.
    • Changing font family should keep the weight.
    • Improved blending of open shapes.
    • Converting a frame text to shape text should position the text correctly.
    • Highlight the last action in the Recent Actions panel.
    • Allow decimal point settings for pixel units also.
    • Separator in palette grid to be optional.
    • Use selected unit in New Document Setup view.
    • Tab key ordering in the the New Document Setup view.
    • Right click menu in New Document Setup template list to remove template if allowed.
    • Add folder tools to the Symbols panel menu.
    • Single inset mode in text frame options.
    • Dragging the scroll bar in the Layers panel should start from the current position.
    • Improved iconified panel handling.
    There is a problem with some text resources in the new beta build. An update will be uploaded today.
  • @VectorStyler said in beta 1.2.011:
    Would someone be willing to elaborate on this feature? For me, the space bar key activates the hand/pan tool whether I press it before or after pressing and using the pen tool.
    @Boldline said in beta 1.2.011:
    When moving a control point, holding the spacebar will move the node with the control point. The new thing here is that this node will also snap to guides.
    I uploaded a fix with the text resources issue.
