Font color in text frame
@b77 Would this work as a global option. Change the frame color or the text color?
And if we need background color, then just use the [+] fill in the Appearance panel.
@VectorStyler Simple click would change the text color, left click add/change the
stroke color just like with regular objects and with shape text ("artistic text" in CDR),
and the 'Background Color' should be a "hardwired" setting — no need to click a
special 'Add Frame Bkgd' button IMO.
@VectorStyler said in Font color in text frame:
Change the text color please. It is a text object after all.
EDIT:
Idea; select with Node Tool > change background/frame?EDIT1:
A preview Selection (text)frame and 'Hovering Sesection' would be useful in that case. Anyway, by the way.
here the Coreldraw way of doing this
color Text is Standard even with Frame Text
@b77 said in Font color in text frame:
special 'Add Frame Bkgd' button IMO.Like this approach.
I will have to find a different way to do this. I will look into what other apps do in this case.
(By "hardwired" I mean it has a button already there but set to 'None').
In the Appearance panel, or in the Color panel?
@VectorStyler A separate 'Background color' entry & color swatch when you
expand the 'Text Frame' object with the triangle button:
(Quick mockup)
@VectorStyler OK, could be that the mockup is oversimplifying
things — this background color needs to be added as content
that can accept transparency masks, effects, etc, right?
