Text disappears
I experience the same. Also the text frame settings are not working properly, inset and column options most of the time doesn't work.
@Kumr said in Text disappears:
Could not replicate this with a basic test. Email me the file where this occurs.
emailed the file. Thanks
Tested with the file and changing the inset seems to be working fine here (both 1.1 and 1.2)
Was the text frame option accessed from the Text menu Text Frame Options command.
@VectorStyler Yes, accessed via Text > Text Frame options.
@Kumr Try reseting the app, not sure what could cause this issue.
@VectorStyler I did the app reset, same result. I completely uninstalled the app and reinstalled the app. No luck.
@VectorStyler Just figured it out. I have to select the text inside the frame for the tool to work, not the frame. Thanks for all the support.
There was a bug when the frame was selected. That should be fixed now in 1.2.004 beta.
Please try again with the frame selection also, and let me know if this works.
@VectorStyler Frame selection is not working here. I am using 1.2.004 beta.
Could not replicate it here. Could be a settings or workspace issue.
Go to the user settings/workspace folder (Help menu -> Reveal Workspace), back up the files and remove the resources folder and the restart.
@VectorStyler said in Text disappears:
Didnt work for me. Same behaviour.
@Kumr I opened a bug on this one and will try to replicate it.
@VectorStyler Thanks
When you confirm the frame options (OK), does the frame change (columns or margins)?
@VectorStyler This is what I am experiencing. Column and inset options work when text in the frame are selected not the frame.
