    3D Help
    27 Posts 5 Posters 35.1k Views 3 Watching
      @Igull
      ok, thanks for the info
      I mentioned quit a while ago in the general section a small 3D tool
      that can import and extrude .SVG files. But unfortunately it is only
      for Windows. (mentioned it because Windows user of VS may be interested)
      Here is the link
      https://www.vectorstyler.com/forum/topic/1238/tip-simple-opensource-text-sgvs-to-3d-object-generator
      You mentioned something like parsing .SVGs. I know that SVGs, are just .xml text files.
      Have you ever thought about a script that parses your SVG file and then creates individual
      object SVG files from them?
      For example, using a script to filter out each shape part from the grouped version and then copy it
      between a header and end part to create .SVGs with only one shape this way.
      I also made a Test in VS where i create some Shapes and then exported them
      once ungrouped and once grouped as SVG files. After that I compared the xml
      texts, the only difference I found was that in the grouped version there is one
      <g> </g> more than in the ungrouped SVG.
      So you could also try to remove this <g> </g> to get ungrouped objects
        @b77 even if he didn’t need the blender information I appreciate that you posted that because it shows me what can be done
          @Igull
          Another strange Solution 🙂
          You might look around to see if you can buy an older inexpensive
          version of Coreldraw for the Mac.
          Coreldraw had even in the older versions an Extrusion Tool.
          Here is a video from my 2020 version
          not much has changed since.
          BoldlineB IgullI 2 Replies Last reply Reply Quote 0
            Boldline @Subpath
            @Subpath said in 3D Help:
            I don't know when it fits on the VS roadmap plans, but an extrusion tool has been requested
            • F Online
              fde101 Global Moderator
              If you really want an alternative you could try something like Cheetah3D ($99), but while it is a simpler package than Blender I personally find it a bit more complicated to use, at least for this particular use case.
              There are other choices but you will pay far more for them than you could possibly hope to gain in any kind of time savings.
              It is fairly simple to do what you are asking to do in Blender, and worth taking the time to learn the basics of that very powerful tool, so I would also push you in that direction.
              A tutorial that may be helpful: https://devforum.roblox.com/t/converting-svgs-to-meshes/884514
              Note that only the first four steps in that tutorial are relevant to what you are asking to do.
                @Igull
                I made a test with .SVG files, to create a single Shape SVG
                from an SVG with grouped shapes.
                By manually copying Text from the xml contend between them.
                (which could be also done by a script)
                For this I created one Shape in VS and exported it
                as .SVG to get a file with only one object.
                I manually then replaced the <path ..... id=""/> Part
                ( which holds the Information for the Shape)
                with a Shape Part from a .SVG with grouped Shapes.
                Worked so far except for the fact that the Shape
                is placed next to the artboard.
                SVG contend with grouped shapes
                The SVG File with only one shape
                The Shape above replaced with this Circle Shape from the grouped SVG File
                (only using copy and paste parts from the SVG (xml Text))
                its placed beside the Artboard, but it works
                • F Online
                  Actually, if you save it as a PDF instead of an SVG you can do this sort of thing in Art Text (https://text.design/art-text/).
                  IgullI S 2 Replies Last reply Reply Quote 0
                  • IgullI Offline
                    Igull @Subpath
                    I hadn't, but that could certainly be an option to at least produce individual part files. It would be a lot simpler if something like Tinkercad would just import the SVG and be able to manipulate the parts individually 🙂
                    Thanks
                    Neil
                    • IgullI Offline
                      Igull @Subpath
                      Yes, I suppose I could do that too, but I have a Fusion 360 and an Onshape licence which can do pretty much anything in 3D - I was just looking for an easy way out with a 'one trick pony':-)
                      Neil
                      • IgullI Offline
                        Igull @fde101
                        @fde101 said in 3D Help:
                        Mmmm, I bought Amadine from BeLight before I found VS - and really quite liked it - albeit a bit lightweight in the features department. I've just downloaded the trial version of their Art Text (supposedly full-featured), but I don't see any way to import a PDF - or anything else for that matter ?? You can certainly create 3D text extrusions and can do some rough vector drawing within, but importing or opening other file formats seems to be missing ??
                        Thanks
                        Neil
                        S F 2 Replies Last reply Reply Quote 0
                          Subpath @fde101
                          could you then extrude shapes from that PDF
                          in Art Text ?
                          I also thought about "Art Text 4" but I thought it could
                          only extrude Shapes and Letters from a .TTF font file.
                          But there are online converters that can convert a
                          .SVG to a .TTF file
                            Subpath @Igull
                            @Igull said in 3D Help:
                            @Igull
                            I think the way to go with "Art Text" is to convert your .SVG File
                            first to a .TTF File via an free Online Converter
                            I have Amadine on my iPad, love it 🙂
                              Subpath @Igull
                              Neil
                              Understandable 🙂
                              But its a bit harder for Mac User.
                              On PC there are a few more Options
                              Here a Extrusion from Magix Graphics Designer
                              which also has such a Tool build in (PC only)
                              • IgullI Offline
                                Igull @Subpath
                                You're rubbing my nose in it 🙂 🙂 🙂
                                  This is not directly related, but I've been giving thought over time to how to best create the 3D wrap around look with a vector path. I was thinking of it in terms of a dedicated shape like the existing oval and rectangle shapes, but now I'm thinking the best way to create those will be when basic 3D extrude is (hopefully) added to VS
                                  0_1685975559387_5932f189-cd44-4ee0-8eac-3fb7d41d5356-BLD 2023-06-05 at 10.24.01@2x.png
                                    Subpath @Igull
                                    I probably should not have done that 🙂
                                      Subpath @Boldline
                                      In Corel you could take any Form/ Shape
                                      (even grouped) and extrude it
                                      in Magix Graphics Designer too
                                      The result in Magix is only a Bitmap
                                      but it has more lightning, beveling options
                                      In Corel it stay as a Vector Object where you could
                                      break apart the parts and reuse them as vector objects
                                      • F Online
                                        fde101 Global Moderator @Igull
                                        @Igull not sure about the demo version, but I have a paid license of Art Text 4, and I can just drag a PDF exported from VS into the Art Text window and it loads it as a 2D shape.
                                        I can then right-click and convert to 3D after which an option to set the extrusion depth becomes available in the properties area on the right.
                                        • IgullI Offline
                                          Igull @fde101
                                          Mmm, tried a number of PDFs all of which dragged across, but didn't show on the artboard (or only showed the bounding box - and you couldn't right click to create 3d)- seems extremely slow and very unstable (tried it on an M2 this afternoon - a bit faster, but same results) - may be something to do with the demo version. But all it has is a TRIAL watermark, everything else is supposed to work according to the info. It's probably fine for doing text and minimal 3D objects I think - might be too much heavy lifting to move all my bits around.
                                          Thanks for the info, I'll keep the trial, might find other uses for it !
                                          Neil
