    3D Help
    27 Posts 5 Posters 35.1k Views 3 Watching
    • IgullI Offline
      Igull @Subpath
      @Subpath said in 3D Help:
      @Igull
      Does it necessarily have to be .SVG as the file format
      for the imported and why ?
      No, it only needs to be a vector format - SVG is the easiest to parse as it's XML and VS exports SVG nicely πŸ™‚
      • IgullI Offline
        Igull @Subpath
        could you post some pics of the Results you like to have ?
        Essentially, they are all a simple flat plate extrude from an object. They don't need shading or shadow.
        Neil
        • IgullI Offline
          Igull @b77
          @b77 said in 3D Help:
          @Igull Blender might be too complex for what you need, but it can
          do it, and it's free:
          Yes, as I said in the intro Blender is far too complex for this situation. πŸ™‚ πŸ™‚ πŸ™‚
          It's also far too involved an application to do this - tinkercad is the level I am looking for, otherwise, I'm just going to end up using Fusion 360 or Onshape and be done πŸ™‚
          The actual output file from the extrude can just be a bit image JPG/PNG whatever as it's going in a simple print document, it doesn't require to be vector.
          Thanks
          Neil
            b77 @Igull
            @Igull Got it, I thought you needed SVG export.
              @Igull
              ok, thanks for the info
              I mentioned quit a while ago in the general section a small 3D tool
              that can import and extrude .SVG files. But unfortunately it is only
              for Windows. (mentioned it because Windows user of VS may be interested)
              Here is the link
              https://www.vectorstyler.com/forum/topic/1238/tip-simple-opensource-text-sgvs-to-3d-object-generator
              You mentioned something like parsing .SVGs. I know that SVGs, are just .xml text files.
              Have you ever thought about a script that parses your SVG file and then creates individual
              object SVG files from them?
              For example, using a script to filter out each shape part from the grouped version and then copy it
              between a header and end part to create .SVGs with only one shape this way.
              I also made a Test in VS where i create some Shapes and then exported them
              once ungrouped and once grouped as SVG files. After that I compared the xml
              texts, the only difference I found was that in the grouped version there is one
              <g> </g> more than in the ungrouped SVG.
              So you could also try to remove this <g> </g> to get ungrouped objects
                @b77 even if he didn’t need the blender information I appreciate that you posted that because it shows me what can be done
                  @Igull
                  Another strange Solution πŸ™‚
                  You might look around to see if you can buy an older inexpensive
                  version of Coreldraw for the Mac.
                  Coreldraw had even in the older versions an Extrusion Tool.
                  Here is a video from my 2020 version
                  not much has changed since.
                  BoldlineB IgullI 2 Replies Last reply Reply Quote 0
                    Boldline @Subpath
                    I don't know when it fits on the VS roadmap plans, but an extrusion tool has been requested
                      fde101 Global Moderator
                      If you really want an alternative you could try something like Cheetah3D ($99), but while it is a simpler package than Blender I personally find it a bit more complicated to use, at least for this particular use case.
                      There are other choices but you will pay far more for them than you could possibly hope to gain in any kind of time savings.
                      It is fairly simple to do what you are asking to do in Blender, and worth taking the time to learn the basics of that very powerful tool, so I would also push you in that direction.
                      A tutorial that may be helpful: https://devforum.roblox.com/t/converting-svgs-to-meshes/884514
                      Note that only the first four steps in that tutorial are relevant to what you are asking to do.
                        @Igull
                        I made a test with .SVG files, to create a single Shape SVG
                        from an SVG with grouped shapes.
                        By manually copying Text from the xml contend between them.
                        (which could be also done by a script)
                        For this I created one Shape in VS and exported it
                        as .SVG to get a file with only one object.
                        I manually then replaced the <path ..... id=""/> Part
                        ( which holds the Information for the Shape)
                        with a Shape Part from a .SVG with grouped Shapes.
                        Worked so far except for the fact that the Shape
                        is placed next to the artboard.
                        SVG contend with grouped shapes
                        The SVG File with only one shape
                        The Shape above replaced with this Circle Shape from the grouped SVG File
                        (only using copy and paste parts from the SVG (xml Text))
                        its placed beside the Artboard, but it works
                          Actually, if you save it as a PDF instead of an SVG you can do this sort of thing in Art Text (https://text.design/art-text/).
                          IgullI S 2 Replies Last reply Reply Quote 0
                          • IgullI Offline
                            Igull @Subpath
                            I hadn't, but that could certainly be an option to at least produce individual part files. It would be a lot simpler if something like Tinkercad would just import the SVG and be able to manipulate the parts individually πŸ™‚
                            Thanks
                            Neil
                            • IgullI Offline
                              Igull @Subpath
                              Yes, I suppose I could do that too, but I have a Fusion 360 and an Onshape licence which can do pretty much anything in 3D - I was just looking for an easy way out with a 'one trick pony':-)
                              Neil
                              • IgullI Offline
                                Igull @fde101
                                @fde101 said in 3D Help:
                                Mmmm, I bought Amadine from BeLight before I found VS - and really quite liked it - albeit a bit lightweight in the features department. I've just downloaded the trial version of their Art Text (supposedly full-featured), but I don't see any way to import a PDF - or anything else for that matter ?? You can certainly create 3D text extrusions and can do some rough vector drawing within, but importing or opening other file formats seems to be missing ??
                                Thanks
                                Neil
                                S F 2 Replies Last reply Reply Quote 0
                                  Subpath @fde101
                                  could you then extrude shapes from that PDF
                                  in Art Text ?
                                  I also thought about "Art Text 4" but I thought it could
                                  only extrude Shapes and Letters from a .TTF font file.
                                  But there are online converters that can convert a
                                  .SVG to a .TTF file
                                    Subpath @Igull
                                    @Igull said in 3D Help:
                                    @Igull
                                    I think the way to go with "Art Text" is to convert your .SVG File
                                    first to a .TTF File via an free Online Converter
                                    I have Amadine on my iPad, love it πŸ™‚
                                      Subpath @Igull
                                      Neil
                                      Understandable πŸ™‚
                                      But its a bit harder for Mac User.
                                      On PC there are a few more Options
                                      Here a Extrusion from Magix Graphics Designer
                                      which also has such a Tool build in (PC only)
                                      • IgullI Offline
                                        Igull @Subpath
                                        You're rubbing my nose in it πŸ™‚ πŸ™‚ πŸ™‚
                                          This is not directly related, but I've been giving thought over time to how to best create the 3D wrap around look with a vector path. I was thinking of it in terms of a dedicated shape like the existing oval and rectangle shapes, but now I'm thinking the best way to create those will be when basic 3D extrude is (hopefully) added to VS
                                          0_1685975559387_5932f189-cd44-4ee0-8eac-3fb7d41d5356-BLD 2023-06-05 at 10.24.01@2x.png
                                            Subpath @Igull
                                            I probably should not have done that πŸ™‚
