Rename Layer Object using Object Options Panel
Looks like renaming a layer object using the Object Options panel is broken. If you double-click the object in the layers panel to bring up the Object Options panel then type in a name, it doesn't save it. If you simply click the layer object name and edit it directly in the layers panel, it changes ok. However, if you double click to get the Object Options panel up again, it shows the edited name in the panel, but you still can't change and save it.
Neil
@Igull Added this to the backlog.
Neil
@Igull Cannot replicate this here, tried both Mac and Windows.
it might be that it has to do with the specific selected object, or the hierarchy.
@VectorStyler said in Rename Layer Object using Object Options Panel:
it might be that it has to do with the specific selected object, or the hierarchy.Have just revisited this today, the issue is still there - as you suggested, it may have something to do with the object - it was an imported PDF of a bit image (around 1Mb) and I see the same thing on a couple of other images on the workspace (also around 1Mb, they're not on the artboard if that makes a difference ??).
I can mail the file if you wish.
TIA
Neil
@Igull Email me the file and a small screenshot of the Layers panel highlighting the object that cannot be renamed.
Mea culpa - the doughnut of the week award goes to me
If an object is locked in the layers panel, you can't rename it in the Object Options Panel - that kind of explains the "issue".
Apologies for taking up the bandwidth, I wouldn't expect to be able to change anything if it was locked.
I did ask if maybe a doughnut popup might be arranged that could fire up saying - Idiot - the item you are attempting to modify is locked
Neil
just "happy accidents", bob ross
@Igull This issue should be fixed in build 1.1.080
This still looks the same to me ? If the object is locked, the rename panel allows you to change the text of the name, but doesn't rename it (as before and as I would expect).
But there's no message or indication to say that the item is locked and can't be renamed ?Neil
@Igull said in Rename Layer Object using Object Options Panel:
This must be the cause.
