    Brush "live" randomization / variation
    27 Posts 4 Posters 41.7k Views 4 Watching
      VectorStyler @Subpath
      @Subpath The "Outlines -> Detail" shape effect, with "Randomized" option enabled.
      If you select the original brush shape on the top left of the artboard, you can see the effect options in the Effects->Edit Shape Effects
        Subpath @VectorStyler
        @VectorStyler , thank you
        • H Offline
          Harry @b77
          @b77 said in Brush "live" randomization / variation:
          @Harry Interesting. Can you explain a bit what the 'Tremor' and 'Wiggle' options do exactly?
          According to Inkscape's tutorial Tremor produces anything from slight unevenness to blotches and splotches. Wiggle is the resistance of the paper to the movement of the pen.
          So yes, as @Subpath mentioned this is not the best example here.
          @VectorStyler said in Brush "live" randomization / variation:
          @Harry This is already doable with some work, by creating a new brush shape.
          But it requires more steps, and a new brush content.
          I added this to the backlog.
          In the attached file adjust the random "Seed" parameter of the shape effect on the top-right object (Effects->Edit Shape Effects)
          0_1670309365492_randombrush1.vstyler
          Yes @VectorStyler , but it's not what I meant. i played with the effects already and I think they're great, but they're still some kind of "post production". What I meant is to have brush randomization applied live.
          My idea is similar to @Subpath and @b77 wave forms concept:
          @Subpath said in Brush "live" randomization / variation:
          So maybe we could go one step further and create a way for a Stroke to randomly switch
          between different (self-defined) brushes.
          My concept is as follows:
          Since we are painters or draftsmen, our tools are stylus and mouse. Let's take 2 different brushes from our presets and styles - Brush A for softest stylus pressure (or minimum mouse velocity) and brush B for hardest stylus pressure (or maximum mouse velocity):
          Everything in between those 2 brushes is a result of "modulator" which changes brush appearance live. "Modulator" should be stylus pressure or mouse velocity dependent.
          Modulator can be for example:
          • blend tool
          • shape effects
          • interpolation
          • randomization
          • variation
          • @VectorStyler 's imagination, etc.
          General purpose should be that effects are aplied live and every stroke is different, even Brush A and Brush B should have little "initial" blending, randomization , roughness etc. to make them different.
          Is it possible? Any other ideas?
          VectorStylerV 2 Replies Last reply Reply Quote 2
            VectorStyler @Harry
            @Harry said in Brush "live" randomization / variation:
            This does not exist in the current version of VS.
            Technically, it could be possible to implement, but some things must be clarified:
            1. From what I see, the "modulation" would vary along the path, based on pressure or some other input.
              This cannot be done with current shape effects.
            2. Also: we have to keep in mind that these brushes are vectors, so would this mean that in case A (soft pressure), the vectors would break into some form of random smaller shapes?
              VectorStyler @Harry
              @Harry I think this "modulation" along the brush path of some distortion parameter is an interesting idea.
              I added this to the backlog. Some details need to be worked out (ideas are welcome), but I think this could be implemented before version 2 (if not version 1.2).
              • H Offline
                Harry @VectorStyler
                1. Also: we have to keep in mind that these brushes are vectors, so would this mean that in case A (soft pressure), the vectors would break into some form of random smaller shapes?
                Yes, that's the point - to simulate natural brush stroke:
                • soft pressure - low opacity, smaller "particles"
                • hard pressure - stroke is more opaque, more solid, more distorted etc.:
                Examples from Rebelle 5 (one of the best natural stoke simulator in pixel world):
                • H Offline
                  Harry @VectorStyler
                  Glad to read that!
                    VectorStyler @Harry
                    This will be hard to do with vectors only.
                    H b77B 2 Replies Last reply Reply Quote 0
                    • H Offline
                      Harry @VectorStyler
                      I know, but results may be surprisingly good!
                      Krita have some more options for modifiers/modulators i.e. stylus rotation and tilting.
                      They call it sensors. Here is some more info:
                      https://docs.krita.org/en/reference_manual/brushes/brush_settings/tablet_sensors.html
                      Maybe for future development?
                        b77 @VectorStyler
                        I don't think Harry meant that VS should strive to imitate natural media brushes
                        accurately like Rebelle does — it's just the random, organic part of the natural
                        brushes that are to be imitated in vectors.
                        As I suggested, picking random brush contours from a "contour table" (similar to
                        wavetables in synths) is one way to achieve this. It's basically stringing them
                        together (with the first and last connecting nodes free to move vertically) and
                        bending them along the brush spine, then maybe overlapping three brushes
                        with different opacities would get you respectably close to the organic quality
                        of bitmap brushes.
                          b77 @Subpath
                          @Subpath I downloaded Alchemy but it's so old that it doesn't work on my Mac.
                            b77
                            Another way would be to have just one brush contour but don't stretch it — instead repeat it but randomize the nodes.
                            Maybe this approach would be faster for "live" drawing.
                              Subpath @b77
                              that, sad to hear, because its a nice little Tool
                              as i wrote works here on Win 10 without any Problem
                              despite that it is from 2010
                              i will create a video to show some Tools of it
                              but this will take yet some time
                                you could try "Webchemy" its a online drawing tool
                                in the style of Alchemy, but have much fewer tools.
                                But a Pull Brush ( you cant define your own Brushes )
                                The Results can be saved as .SVG an PNG.
                                Here the Link
                                https://webchemy.org/
                                  b77 @Subpath
                                  @Subpath Ouch… Webchemy is rough… 🙂
                                    Subpath @b77
                                    thats true 🙂
                                    • H Offline
                                      Harry
                                      I found temporary workaround also in the Stroke Width panel's menu - there is "Randomize profile" option. Still it's "post production", not "live" and not exactly what I meant:
                                        VectorStyler @Harry
                                        @Harry If there are some good inspirations on how such a brush should look like, please upload here or send them to me by email.
                                        • H Offline
                                          Harry
                                          Problem is, that I don't know.
                                          Let's say I'd like to design some abstract pattern. I would take "Live random effect brush tool", and I would experiment and look for some inspiration from great and interesting shapes this kind of brush could produce.
                                            @b77, @Harry, @VectorStyler
                                            Hi
                                            As a source for inspiration, for modulate Strokes, the painting program
                                            Black Ink came to mind.
                                            "Black Ink" uses a kind of controller nodes to modulate brushes
                                            to set and control random strokes and has a node system for layers.
                                            Here are some videos
                                            Video about the Brush Controllers:
                                            Black Ink Brush Controllers
                                            Video about Black Inks Layer Nodes:
                                            Black Ink Layer Nodes
                                            Scattering a Brush may also be interesting
                                            her a Video about it
                                            Scattering a Brush with Controllers
