    Extend Square Star by one Point
    29 Posts 5 Posters 43.5k Views 4 Watching
      VectorStyler @Subpath
      @Subpath Yes that is the "Shape" role. It can also be set in the Object Options view with the Role button.
      The difference:
      When using the Shape role a "virtual" shape style is created (think of a shape style as a fill or stroke style, but for shapes).
      This shape style can then be selected on any object to be the shape of the object. These objects will not be symbol instances, and they may have any other local attributes, but their shape is linked as a style to the shape style.
        Subpath @VectorStyler
        thank you for the explanation.
        Could you briefly explain how I then pass this "style" to other objects ?
        I think I figured out how to do this.
        Select Panels > Styles > Styles (alt+v).
        Open Shape in the panel and here is your previously
        created Shape role
        Select the object(s) you want to apply it to and press the icon in the bottom
        left corner. To test it, just scale your original object
        Did some tests:
        Node editing is possible
        Group shapes after you applied the style too
        Even composite objects work (not possible with clone)
        but give me a fixable strange position for an object inside the composite object
        will explore this further
        Video: here my results
          @Subpath When an object is selected, the Shape panel (and the Context panel) will contain a "Shape" drop down, that lists all the Shape styles and presets.
          Select the shape from there. The shape is listed with the name that was assigned to the object with the Shape role.
            @Subpath Yes, the Styles panel also works for this.
            • Victor VectorV Offline
              Victor Vector @Subpath
              @Subpath said in Extend Square Star by one Point:
              shapes without scaling point
              shapes with a scaling point
              For consistency, and to clean up the Shape Tool "blue point" interface, it wouldn't bother me if there were no scaling points, but scaling was achieved via the Transform Tool, or the Shape Panel.
              But I do like the "one point" scaler idea too!
              @b77 said in Extend Square Star by one Point:
              And… it all looks a bit busy. Maybe use just one knob for scaling?
                Subpath @Victor Vector
                @Victor-Vector
                As from my point of view, i dont know the cause that Point for scaling by now.
                It doesnt matter that much to me if there is one or non.
                So i have nothing against your Idea, if you like one.
                The Post of mine where you reply to is just an observation i made.
                  b77 @Subpath
                  Having a knob or knobs for scaling the shape when in Shape Editing mode (shortcut: A) means you don't have to switch to the Move/Transform tool (V) for scaling.
                  So I'm not suggesting it should go away.
                    Subpath @b77
                    A knob for scaling can stay. I have nothing against it.
                    But it is surprising why some Shapes have one and others do not.
                    Victor VectorV b77B 2 Replies Last reply Reply Quote 0
                      @Subpath, I hear what you are saying. I advocate for the consistency as well.
                      @b77, I really like the single scaling knob idea as it creates less confusion in the interface.
                      Thank you for sharing those ideas.
                        b77 @Subpath
                        You mean the rectangle and the ellipse? These are not usually supposed to be scaled symmetrically from the center like the polygon/star based shapes.
                          Subpath @b77
                          understand your point about the rectangle and the ellipse.
                          i mentioned the shapes above in my post
                          here again the picture with all shapes without a scaling knob
                            b77 @Subpath
                            @Subpath Sorry, I didn't see that image. Yes, the Super Ellipse and Super Shape could have a scaling knob, I agree. πŸ‘
                              Subpath @b77
                              no problem πŸ™‚
