Sharing workspaces between operating systems
Opening a workspace file from macOS in Windows imports OS specific keyboard shortcuts as well - and then keyboard shortcuts do not work.
Control + Z turns into Cmd + Z in the menu and stops working. Etc.
@Ingolf Yes, this is an issue for now, as most of these customization end up in the workspace file. There is an item in the feature backlog to separate the toolbox, shortcuts, menu from the workspace.
@vectoradmin Goodie goodie, I removed the solid chunk of shortcut data from the XML manually, VS didn't complain during import.
You should consider implementing one setting importer-exporter where the user can select exactly what categories of settings to import or export so this important feature is not fragmented and spread out across the program interface.
This could also reduce the differences between the macOS and Windows menus.
@Ingolf said in Sharing workspaces between operating systems:
You should consider implementing one setting importer-exporter where the user can select exactly what categories of settings to import or export.
Yes, this is in the backlog.
