      Child shape alters the parent shape when both have the Shape Effect added
      • A Former User
      3796
      @VectorStyler Well, I think you are right. I didn't connect the dots! My bad. Some of those hidden options really need icons.
    • Path not closing
      • Devil Dinosaur
      7284
      @Devil-Dinosaur Great!
    • Width/Height not changing after object rotation
      10037
      @VectorStyler OK, understood - I'm just happy that I can set it to my liking
      Opacity of object reduced when grouping objects
      • MajorTom
      6890
      @MajorTom Not sure if I identified the issue: what I get is that when I move the "{Path} Copy" into the group, the effect becomes lighter. This is caused by the opacity set on the group. When the group is selected the Appearance panel will show an opacity value of 86% for the group.
    • Symbol spray brush
      5713
      found that moving fields in context toolbar also annoying e.g. the field for Stroke width that's why I often use the Panel even though that I do not necessarily advocate the affinity approach, still wish for a better solution
    • Misleading use of check marks in Panels menu
      5536
      Would three states for the checkmarks work for this or confuse users? Or a hyphen/line instead? In any case, the checkmarks look too big on Windows… I would pick some smaller checkmark glyph that has a smaller than 90Β° angle, like on the Mac.
    • VS randomly switches to pixel view
      5322
      @Boldline @b77 Since 2 releases ago when the Display settings are changed, the changes are used as defaults for a new document.
      Issues with the Pen tool & Intuos4 tablet
      12910
      @VectorStyler much better now I'll test further. Thanks.
    • Cannot get rid of stroke and it changes color in odd ways in the color panel
      6890
      @VectorStyler the original expanded text is in the large file I emailed to you about an hour ago if you want to compare and contract it. I may have done some editing since that time on it before moving it to a new file to see if the issue continued there.
    • Character Style Interface issues - 1. Names, 2. Display.
      • Victor Vector
      4944
      @VectorStyler said in Character Style Interface issues - 1. Names, 2. Display.: @Victor-Vector I could not replicate (1). Was there any UI settings changed, like font size, or UI scaling? Yes, I increased the Font size in the VS preferences. The UI scaling is at 150% in Windows 11 (but I am shy to advertise this as it means my eyes are not what they used to be) (2) can be replicated, added it to the backlog. The right side supposed to be a preview of all the settings made in this view (could add a label there). Ah, I thought it was a preview. It did not seem to be previewing...
    • pen tool with the guide on to preview where the path will go, the preview looks very extreme
      2868
      @Boldline I think this is a bug in the pen tool preview. Added this to the backlog.
      Mesh gradient editor
      • freggern
      28
      28
      45409
      @vectoradmin Doesnt work also on Win. Only not on Line. Double click inside the mesh work.
    • Mesh gradient editor not working
      3064
      @Ingolf I tested it on Windows also. Adding a new mesh node is done with double click inside the mesh area.
    • Pen tool often gives me an overextended section when I try to click on the last node placed
      26
      26
      39763
      @vectoradmin Awesome! thank you for helping me solve that problem!!! it works so much better now
    • Fonts list closes when using the scrollbar [1.1.010]
      9986
      Fixed! Thank you.
      tool palette disappears: what made it disappear ?
      • BWoo
      3104
      @BWoo The tool palette can be displayed or hidden from the Panels menu > Toolbox. There is no shortcut assigned to it.
    • Erasing section of Vector shape alters red dot rotation point
      3410
      @vectoradmin ok thanks - I like and prefer the added function, so for now I'll leave it and see how things go
      1.1.032 - minor bug with text context menu
      2490
      Adjustment effect icon in layer
      8925
      @vectoradmin Thank you. Solved by changing to software.
      Aliased horizontal lines
      • gentlecl
      6073
      @vectoradmin said in Aliased horizontal lines: @gentlecl Did you try setting the View -> Subpixel -> Maximum mode? I think it should be somewhat better. I am an idiot Thanks , that solved the issue
