      UI Display Issues 1.1
      • FastVector
      2939
      @FastVector said in UI Display Issues 1.1: But you can also maximize a window by draging them to the top of Windows, and then the problem occurs. Yes, this can be replicated here also. I will try to fix it as soon as possible.
    • I
      duplicate object lag & snap indicators invisible
      • Iriseg524
      8858
      @Iriseg524 You should have a new license now.
      Png display issues
      • William Kansepa
      2159
      @VectorStyler This issue has been resolved in VS 1.1.116. Thank you so much @VectorStyler!
    • Copy/paste objects from Affinity Designer to Vectorstyler- bug
      • visualrevolt
      2418
      Designer vers 2.2.1
      Issues with The Artistic Brush
      • Li Xiao
      3387
      @VectorStyler Thanks, I got it
    • Eraser Regression
      2927
      @Igull said in Eraser Regression: assumes that shape shouldn't be broken and the fill removed Yes, it only breaks apart if the eraser results in separate paths.
    • O
      Adding a Anchor Point After Path Reversal
      • oleGraf
      3953
      O
      @Boldline Thank you for your video. It does a good job of illustrating my original post. Appreciatively.
      Slow Typing Performance
      • gotanidea
      4900
      @gotanidea No, this is still an open problem. There was a related bug that it was solved, but the other case (very large text frame) is still open. I found that on a regular artboard size, 12pt frame text typing is alright. It gets slow with very large frames and small text. It is an open bug, and will get solved in the 1.2 phase.
      The shapes corner bug
      • Li Xiao
      2173
      @VectorStyler The bugs have been fixed Thanks
      Flip repeater content problem
      repeater • • Li Xiao
      4069
      @VectorStyler fixed thanks
      Beta 1.2: VS crashes when a panel...
      4426
      @VectorStyler said in Beta 1.2: VS crashes when a panel...: @Pat said in Beta 1.2: VS crashes when a panel...: because there is no 'send' button Just use the "Close" button, crash reports should be sent. Fine, it is what I did
      B1.2: issue when trying to adjust the width of the panels when docked
      1859
      @Pat Yes, this is by design for now, the first column will just move.
      Some issues regarding the mesh
      • Li Xiao
      2400
      @VectorStyler said in Some issues regarding the mesh: @Li-Xiao Yes, mesh inside artistic brush will not work for now. I added this to the backlog and will try to find a solution for this in the future. Meanwhile, keep the content of artistic brushes to pure vectors. Looking forward to updates regarding the mesh. I have used Mesh Tormentor and very like it www.meshtormentor.pp.ua
      Image effect
      6305
      @Pat Got it!
      Document format - the wrong one
      2241
      @VectorStyler even if I make a new format from scratch, I get the square format back.
      Shape effect
      3089
      @Pat said in Shape effect: is it a new feature to be able to get a stroke on an object with a colour mesh ? Yes, it was requested. The problem here is that the shape effects cannot subdivide the mesh, but can subdivide the object shape.
      Spiral Wire Size and Accuracy Issues
      • Li Xiao
      1925
      @Li-Xiao I added this to the backlog as a bug.
      The shape text corner bug
      • Li Xiao
      2260
      This error has been fixed. thanks
      Paning (H or Space shortcut) doesn't work after applying effects
      1878
      @Harry Yes, this is by design. The pan tool (or any other tools) are blocked while in a modal view. I will try to improve this in the future if possible. Meanwhile, it is better to use the Shape Effects panel to edit effects and have panning available also
      Change blend mode back to normal is not possible
      2267
      @Harry Meanwhile as a workaround, try using the scroll wheel or the up/down keys. EDIT: the up/down key use works when the list is not open, just click on the Blend label and press the up or down keys. The scroll wheel should work by just hovering over the blend field (without opening the list).
