Ungouping multiple groups with single shortcut press.
If I select a few groups of objects in a Layer Panel than I have to press ungroup shortcut for each group. Ungrouping takes place one after the other.
@encart Can confirm that. You can however use 'Ungroup All' from the Object menu.
@encart Did you use the ungroup icon at the bottom of the Layers panel, or the Command+Shift+G shortcut?
@vectoradmin This happens on the Mac when clicking the fifth button at the bottom of the Layers panel, and I guess it's the same on @encart's PC.
@vectoradmin I used Shift+Ctrl+G shortcut, but icon works the same way.
https://recordit.co/VD9RvVGUYI
@encart Added to the backlog as a bug.
