    Ungouping multiple groups with single shortcut press.
    6 Posts 3 Posters 6.7k Views 1 Watching
      encart
      If I select a few groups of objects in a Layer Panel than I have to press ungroup shortcut for each group. Ungrouping takes place one after the other.
        b77 @encart
        @encart Can confirm that. You can however use 'Ungroup All' from the Object menu.
          VectorStyler @encart
          @encart Did you use the ungroup icon at the bottom of the Layers panel, or the Command+Shift+G shortcut?
          b77B encartE 2 Replies Last reply Reply Quote 0
            b77 @VectorStyler
            @vectoradmin This happens on the Mac when clicking the fifth button at the bottom of the Layers panel, and I guess it's the same on @encart's PC.
              encart @VectorStyler
              @vectoradmin I used Shift+Ctrl+G shortcut, but icon works the same way.
              https://recordit.co/VD9RvVGUYI
                @encart Added to the backlog as a bug.
