Still annoying problems with exported pdf's
VS has improved handling pdf-export (I feel), but there is still serious problems.
It's not optimal – when exporting pdf's – selectable text information must be switched off (Vector Text selected) for acceptable typography.
@Raaskot I will try to improve this.
@Raaskot Not sure what could happen here as I cannot replicate the problem.
I opened the attached PDF files in both Preview and Adobe Acrobat and it seems to render the glyphs correctly:
Here is a smaller text I exported (different Cachet font).
0_1710747540045_exportfont1.pdfAre you using Preview or Acrobat in those screenshots?
I have used both Mac Viewer and Acrobat Pro (and Google preview)
"Driftsafdeling" (as you'll notice) does not at all seems to render acceptable ...Though "0_1710747540045_exportfont1.pdf" seems fine.
Also I can't figure out why the difference (aside color) since it's identical font. Do you have any idea?
@Raaskot I will try to find out what could cause this.
@Raaskot Can you send me a PDF exported from VS where the different color with same font is broken.
I think this might also be dependent on font type, and I do not have the exact same font.
I'll send files on email ...
@Raaskot The problem can be replicated here also. The fix will be in the next build.
