The issue with flipping symbol objects within a clipping frame
The issue of symbol objects disappearing when using the Flip Copy Object feature
It seems that there are multiple issues related to clipping frames, such as refresh problems and object loss.
@Li-Xiao I opened a bug on this one.
@Li-Xiao I could not replicate this using the file and the steps in the recording.
@VectorStyler I tested on two computers and encountered the same issue. I have closed all other software for testing purposes. After “Restore Defaults”, the problem was resolved. It's a strange issue, and I will try to investigate the cause further.
@Li-Xiao If occurs again, go to the user data folder (Help -> Reveal Workspace Folder) and send me the files from that folder. This folder contains the VectorStyler settings and workspace files.
@VectorStyler got it
@VectorStyler I have identified the steps to reproduce the bug, and I will try to reproduce the two other issues that cause program crashes. Once I successfully reproduce them, I will send you the settings and workspace files.
replicate video
https://youtu.be/WMMDP4p3RywThere is another issue causing the program to crash, but I couldn't replicate it again. I have already sent the settings and workspace files.
@VectorStyler fixed. thanks
