The bug causing program crashes when using Elastic Warp
The program crashes when the Density parameter of the Elastic Warp effect is set to 300% or higher.
@Li-Xiao Thanks for reporting this. I will try to fix it for the next build.
@VectorStyler Fixed. thanks
