The issue with the automatic refresh of cloned shapes
When a cloned shape is within a clipping frame, it does not automatically refresh when the original shape is modified. After manually refreshing it once, it functions normally.
When using the Clone Shape with Repeater, didn't automatically refresh when modifying the original shape.
After applying the Twirl effect to a non-cloned shape that has been Repeated, placing it inside a clipping frame, the display incomplete when the clipping frame is moved.
@Li-Xiao Thanks for the additional info, I opened a bug on this one and will try to fix it ASAP.
@VectorStyler Perfect, everything has been fixed.
