beta 1.2.008
VectorStyler 1.2.008 release notes
General stability improvements.
Fixed a bug in printing gradients with MacOS printer drivers.
Fixed a bug causing settings and workspace file storage issues.
Highlighting text with formatting imported from SVG file.
Improved paragraph style synchronization.
Fixed a bug in the text editor when editing stretched text shape.
Fixed a bug in editing locked size in Shape panel.
Stroke width brush to handle composite shapes correctly.
Fixed a regression in the fill button accessed from the context panel.
Allow shape references from repeaters.
Fixed a bug in the Shape Corner effect when selecting the corner type.
Ungroup bent objects to keep the correct bending frame.
Fixed a transform pivot point snapping issue.
Undoing convert to curves on groups of clones.
Better character positioning in imported SVG files.
Improved OpenType form handling.
Fixed a bug in using the contour tool on multiple objects.
Place the text cursor to the end when editing the selected text shape.
Uniform icon spacing in panels.
Improved docked panel resizing.
Improved tint handling in the color panel.
Joining multiple objects with the path brush to create the correct shape.
Improved displacement shape effect precision.
Improved contour and offset path effects on text shapes.
Fixed the bucket fill tool cursor positioning problem.
Show associated panels when double clicking on some tools.
Updating fill and stroke options in popover views after undo.
Add DPI value for the selection info of images.
Switch to the previous document when closing a document.
Option to split mesh shape when applying distortion effects or using the mesh inside a vector brush.
Small drag in drawing tools should nit open the modal view.
Better snapping in the reflect tool.
Do not show path extension in the Pen tool when smooth mode is enabled.
Use maximum for proportional scaling.
Allow color palette editing with closed documents.
Fixed the missing icon for the color group heading.
Fixed a bug in arranging artboards into a grid.
Fixed a bug moving and transforming inside composite shapes.
Fixed a crash caused by copying blend objects.
Keep node types after union operation.
Expand Symbol action activation.
Replacing content from the Links panel should update objects correctly.
Panels should not resize after changing preferences.
Fixed a bug in customized toolboxes.
Stroke scaling option to work correctly inside blend objects also.
Maximizing a window by moving should set the correct maximum size (on Windows).
Fixed problem with using Nvidia CUDA on Windows.
Better handling of the right Alt key on Windows.
Improved magic wand selection by shape size, length and area.
Do not show the All Artboards checkbox when accessed from document setup.
Fixed a bug in restoring iconified panels.
Restore default brush tool options from the presets drop down.
Repeat with duplicate using the option(alt) key.
Show tool tips for iconified panels.
Improved the Transform panel layout.
Uniform panel margins.
Open the Symbols panel from the symbol spray tool.
Improved symbol parameters handling.
Improved number variable editing.
Added preset lists in brush type views.
Group object styling to reset when referenced group is changed.
Remove red background from file previews.
Adding nodes should not change the path position.
Erase blend mode to work correctly with other blend modes.
Keep the isolated and knockout mode options when drawing new objects.
Fixed bugs in the icon customization view.
Fixed a bug in the double click to node tool setting.
Changed the Grid and Guideline showing commands.
When I attempt to download 1.2.008 beta, I go to the pinned topic "Vectorstyler 1.2 beta" and click on the link "Windows 10/11"It starts to download a file called "Vectorstyler.msi" (no version number, so hard to keep straight).
Clicking to install this file seems to install Vectorstyler 1.1.117, but not the 1.2.008 Beta.I am in the wrong place?
I was about to post the same issue
Thanks @Pat for confirming.
@VectorStyler, a bit more detail:
I originally tried to update the by running the 1.2.007 Beta app, and then it presented me with the pop-up to update to 1.2.008 Beta. I clicked "update" then "install" and it seemed to have installed the 1.1.117 update instead...
It was after this I tried to do the manual install by going to the "VectorStyler 1.2 Beta" forum link, and it seems like this is the same mistake.
@Victor-Vector I can confirm this. I did repair several times 1.117
@Pat @Victor-Vector Should be fixed now, sorry for the mixup.
@VectorStyler no problem at all. Thanks for the updates
Thank you! I can confirm it works now if you download the file from the pinned topic "Vectorstyler 1.2 beta" and click on the link "Windows 10/11"I highly recommend putting version numbers on the .msi files.
@VectorStyler I appreciate the new update with all the bug fixes and improvements. Thank you!
