update 1.2.005
    VectorStyler 1.2.005 release notes
    • Improved the data sources panel (1.2).
    • Restored node size in settings.
    • Set text color when setting color for a selected text frame.
    • General stability improvements.
    • Fixed bug in duplicating multiple text frames.
    • Expanding bristle brush on certain curves.
    • Fixed bug in bristle using width profiles.
    • Improved path offsetting and stroke profile handling.
    • Fixed bug in outline zigzag effect on complex shapes.
    • Blending and contour of stroke cap shapes.
    • Artboard label settings to be used on artboards.
    • Added a preview button to the create guidelines view.
    • Text baseline path should not extend beyond text.
    • Better tracking handling with text on path.
    • Creating text on path with selected shape to position the path correctly.
    • Show correct font when a new paragraph text is selected.
    • Updating selection presets to capture selection correctly.
    • Number fields in text formatting options to use the font size units.
    • Selecting text should work between multiple linked frames.
    • Do not add extra leading before the first line.
    • Fixed bug when exporting to PDF with certain fonts (SF Pro).
    • Fixed a bug in adding large corner to rectangles.
    • Fixed a bug when rearranging artboards in the canvas panel.
    • Allow corner shape preset and style creation from composite and closed shapes also.
    • Show outline while hovering with the node tool for parametric shapes also.
    • Show text cursor when creating an empty text frame.
    • Document save indicator to update when opening a document.
    • Fixed a bug with the select shape and link shape commands.
    • Fixed a regression in using host system hyphenation options.
    • Hyphenated works should highlight correctly.
    • Allow exit from isolated mode with the node tool also.
    • Deleting nodes around straight lines should keep lines straight.
    • Fixed a possible crash when using style and symbols links.
    • Keep the correct position when creating reference form an object.
    • Do not change symbols with color filters (requires expansion first).
    • Fixed a bug with the small caps (and petite caps feature.
    • Allow width profile node deletion in the modal view also.
  • @VectorStyler said in update 1.2.005:
    @VectorStyler & with "All artboards on canvas" ☺
    Very helpful, thanks ☺... and of course for all great improvements
