Bug : No Preview and Crash on "Add new nodes ...." Feature
Tried the "Add new nodes to a path using various node position"
Feature in the newest VS 1.2 Beta and i register that the Preview
doesnt workAlso got a Crash
I know that this "Add new nodes ..." Feature works only when i select a path
via the Transform Tool. Which make me wonder.But i tried it anyway with the Node Tool by selecting only a Part of a Path,
i selected 2 Nodes and want the new Nodes between them and VS crashes.
Crash report is send.General question about this feature:
The way this feature is applied baffles me.
I need to select a path using the transform tool
to then add new nodes. But how do I proceed if I only
want to assign the new nodes to a specific Path segment?I would have expected this feature to be applied with the Node Tool.
@Subpath said in Bug : No Preview and Crash on "Add new nodes ...." Feature:
But how do I proceed if I only want to assign the new nodes to a specific Path segment?
This might be a bug.
@Subpath @VectorStyler I think it works fine, need to activate the display nodes of the selected object (Edit\Setting\Selection\Show Nodes of Selected Shapes). but the functionality needs to be strengthened, like selecting only a part of a path.
Yes, I also think that it works well if you select the path with the Transform Tool.
But I also found this approach a bit irritating and would have expected it to also
work between nodes selected with the Node Tool.Thanks for the tip about setting the “Show Nodes” flag
I hadn't thought of that.
@Subpath your welcome.
I previously bought a macro for CorelDRAW and it has some nice node-related features.
http://gdgmacros.com/details.php?prodId=286&category=14
It's a pity, it has stopped updating.
@Li-Xiao said in Bug : No Preview and Crash on "Add new nodes ...." Feature:
It's a pity, it has stopped updating.Looks interesting
As far as I know, CorelDraw has a scripting part.
The last time I used this it was Visual Basic,
so if some are a little adventurousBtw Scripting is also on the Roadmap of VectorStyler.
