Locked icon for artboard size doesn't update value
When you are trying to change the artboard size in the Canvas Options panel, if you lock the width/height values, the height value will not update as you type in the width value. The height value will not update even after you press TAB (which it should). It works fine for the Canvas size (in the Canvas tab) but nor for the artboard.
- Create a document
- In The Canvas & Artboard Panel select the canvas (Canvas 1) and bring up its properties (Canvas Options dialog).
- Select the Artboard tab.
- Make sure the lock icon for widht/height is unlocked.
- Type in the same value for both (eg 100).
- Now that both widht and height is the same, lock the lock.
- Type in a value for the Artboard Width and press TAB. The height will not update. It should update to the same value, or if you want proportions, it should update the height value by the same aspect ratio.
- Now do it the other way. Type a value in the height field and press TAB. The width value will update. But not the other way around.
Video:
https://www.youtube.com/watch?v=IRa96S2NQSIVS 1.1.95
PS: Seriously, when I'm going to get paid? The app is wonderful with all the features and tools but the amount of bugs and glitches are too much. I won't be able to do this for long. I don't have that much free time. Name a tool or feature and I will break it or find a glitch with it in a few minutes.
Also, look at this one...
- Create new document
- Select the Canvas (Canvas & Artboard Panel)
- Open Canvas Options dialog and select the Canvas tab.
- By default the "Default Size" checkbox is checked. Uncheck it.
- By default canvas width and height is set to 5px and lock icon is locked.
- Select the canvas height value and type 100.
- Press TAB to select the width value and type in 100. Now the height value has changed to 20,000!!! That aint' right for sure.
@pentool Added this to the backlog, will try to replicate it.
