Corner Fulcrum Bug ?
If you look at the Corner Panel > Panels > Corner
down below at the right side the X in circle
will delete all rounded corners from a selected shapebtw you can create a Action for the needed Steps
see pic below
( unwanted recorded Steps can be deleted in the Action Panel)
@Igull said in Corner Fulcrum Bug ?:
Resize the rectangle using the width and height boxes
Question regarding the original post:
Do you have the "Direct Shape Transformation" option enabled in Preferences -> Editing Options 2 (bottom right checkbox) ?
@VectorStyler said in Corner Fulcrum Bug ?:
Do you have the "Direct Shape Transformation" option enabled in Preferences -> Editing Options 2 (bottom right checkbox) ?No, I don't
I've set that now and the issue has gone !!!! I've tried with various shapes and none are an issue when resized now - just perfect, thank you !!!!!!!!!!
Neil
Not yet! I think paths should also support this direct shape transform and I added it now.
@VectorStyler If the next build will have changes related to all this, please explain the changes here when it's released.
@b77 said in Corner Fulcrum Bug ?:
Before I forget:
The only change that will be in the next build is that when a free path (not parametric shape) is scaled or rotated and the "Direct Shape Transformation" is enabled (already exists), then instead of adding a "nondestructive" transform to the object, it will just scale the path, leaving the corners "rounded".
