Separator Line Bug
Hi
Seems that there is a bug when attempting to add a separator line in (say) the contextual menu editor.
You can only add a separator line if you are within a folder. If the menu contains no folders, then you can't add a separator.
Workaround is to add a folder, select the folder and add a separator. You can then move the separator out of the folder to where it is required then remove the folder.
Of course, this could be yet another case of me not doing a RTFM
Neil
@Igull This sounds like a bug. I added it to the backlog.
